And you thought you knew something about nails and screws!
   / And you thought you knew something about nails and screws! #11
Same here.
I don’t know where all the rumors that you shouldn’t frame with screws got started. Obviously you shouldn’t use drywall screws but any deck or structural screw is going to be far stronger.
   / And you thought you knew something about nails and screws! #12
Yes... drywall screws have little shear strength, and no pun intended... structural screws are just that; you just hit the nail on the head. (y)
Also, have you seen the new lag type screws for rafter tie ins? Really nice to hold a roof down.
   / And you thought you knew something about nails and screws! #13
The ones about 6” long and painted orange or something different?
   / And you thought you knew something about nails and screws! #14
because when screws break they let go instantly and provide no warning of failure, nails bend, and provide somewhat of a warning before failure. I have read it in a couple framing books and random places.
   / And you thought you knew something about nails and screws! #15
Only drywall screws. Any decent screw won’t break.
   / And you thought you knew something about nails and screws! #16
Sorry buddy, I have multiple snapped outdoor screws in my deck the 2nd year i built it, can't think of the brand, but the yellow and gray ones from HD and lowes. never thought i would see it.
   / And you thought you knew something about nails and screws! #17
Probably made in China... Good screws are way expensive...
   / And you thought you knew something about nails and screws! #18
Were they stainless?
   / And you thought you knew something about nails and screws! #20
Can we STOP blaming China?
Without reading what the screws are rated for it's totally a non-sequitur.
As mentioned above, there are structural screws, and structural means they're manufactured with specific metals/alloys to meet structural requirements. Screwing down deck boards isn't really "structural" in the way that framing is.
I used Simpson-specific structural screws on some floor joists and for some rafters (both different projects). A LOT easier than trying to swing a hammer in a tight space. More costly? You bet. But, having a worn out arm (of smashed hands) can be even more expensive.
I'll likely use those nifty rafter screws if I build a new house. I'd love to be able to rent one of the tools for installing them: not sure what they're called.
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A51039)
Morooka MST 660VD...
2015 CATERPILLAR 336FL EXCAVATOR (A51242)
2015 CATERPILLAR...
PALLET OF FUSION EQUIPMENT (A50854)
PALLET OF FUSION...
2022 Ram Bighorn 2500 4X4 (A51039)
2022 Ram Bighorn...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
