Simpson engines
   / Simpson engines #1
Dave Pic
JD 5203
Just how are the Simpson motors? Just bought a 2605H. Have heard both good and bad. Of course, its too late now..., but looking for real world knowledge.
   / Simpson engines #2
It is essentially a Perkins knock off - you should have very little trouble with it and they are usually good on fuel consumption.
   / Simpson engines
Thanks. So far so good, only 26 hrs, but it does seem a little better on fuel than my JD5203 was, and that was really good
   / Simpson engines #4
Hey there, I have owned a 2605H (two wheel drive version) since... 2017 with no issues.
200-some hours, I do oil/filter changes annually since I am a low-hour user.
I bought it to work with the 1947 Ferguson 3 bottom plow [ I like draft control ]
When you get an orange light on the dash - purge the water from the fuel filter.
It uses an electronic sensor [vs a glass bowl that you can look at].
   / Simpson engines #5
Forgot to mention - I use Pat's quick hitch [using the cat 2 -> cat 1 stepdown model since all of my imps are 1]
Fitrite hydraulics top link (Brian knows to ask which version of 'Pat's you are using since the geometery is different across the decades).
2014 CHEVROLET SILVERADO (A50854)
2014 CHEVROLET...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
1985 International X Con Semi (A50514)
1985 International...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2024 MERCEDES-BENZ SPRINTER 3500XD BOX TRUCK (A51222)
2024 MERCEDES-BENZ...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
