And you thought you knew something about nails and screws!
   / And you thought you knew something about nails and screws! #1
k0ua
Epic Contributor
Branson, Mo.
Kioti DK35se Hydrostat
I bet some of you will be surprised at these results of testing various nails and screws for holding power and a simple corrosion test.
And while we are at it, how about testing shear strength too!
   / And you thought you knew something about nails and screws! #2
He needs to slow down a bit with that chop saw.... :)
He should have kept the pulling device from rotating while pulling up. Not a fair test to allow the steel piece to rotate with the nail while pulling.
Few nails are rated for withdrawal resistance.
   / And you thought you knew something about nails and screws! #4
Thanks James...........That was interesting.
Cheers,
Mike
   / And you thought you knew something about nails and screws! #5
As Repete pointed out- allowing the lifting device to freely rotate while pulling out the spiral shank nail, makes the test of that fastener type, null and void. He basically unscrewed it. Seems kind of disingenuous to make the video and place it in last place, without at least verbally mentioning that in a real world application, the fastened parts would not be pulled straight out while rotating.
   / And you thought you knew something about nails and screws! #6
Yep...Good point........Guess one would know that if they ever tried to "pull" a spiral nail.
   / And you thought you knew something about nails and screws! #7
I had seen this before and I was shocked. I knew screws were better but I had no idea they were that much better. Deck screws are way more expensive and take more time but I use them for just about everything.
   / And you thought you knew something about nails and screws! #8
No surprise that screws won the competition and ring shanks came in second but I was surprised how well the galvanized nail held.
No surprise that screws won the competition and ring shanks can in second but I was surprised how well the galvanized nail held.
Same here.
   / And you thought you knew something about nails and screws! #10
I have been watching Project Farm videos from the beginning. At first his tests were very unscientific. He just wasn't doing a very good job with controlling variables. But with each video he seems to improve a little. And even his first videos have good and useful info in them. I have made some suggestions to him, he thanked me directly, and later used these suggestions to get more accurate results. I am sure others have too because of the way he keeps improving his testing methods. I think he must read all the comments and acts on the good suggestions he gets. I have to hand it to the guy, he must spend a lot of time on his videos. Videos that don't advertise, don't have stupid hype, and show the testing of stuff used in the real world.
Eric
Greenhouse Panels (A50860)
Greenhouse Panels...
2015 MACK GU 713 (A50854)
2015 MACK GU 713...
UNUSED Black Metal Roof Panels (A50860)
UNUSED Black Metal...
2003 Wells Cargo Enclosed Gooseneck Trailer (A50860)
2003 Wells Cargo...
UNUSED Galvanized Wire Rope with G70 Hooks (A50860)
UNUSED Galvanized...
2015 Lexus RX 350 SUV (A48082)
2015 Lexus RX 350...
