Which TYM engine
/ Which TYM engine #1
Docwho
Member
Howard, PA
New Holland/TC40
Looking into TYM, they offer models with the Yanmar (powers a lot of compact tractors) or Kukje (unfamiliar with this make).
Is there a benefit of one or the other?
/ Which TYM engine #2
Yanmars are great engines as they are in everything. I went with the Kukje, it's a Cummins A series engine which Kukje is licensed to build. Parts are available for these engines throughout the country, although you probably will never need anything but filters for either engine. The Kukje has no computer controlling the engine, only the stand alone DPF system in my tractor. It's been a good engine for me so far, no issues starting in cold weather.
/ Which TYM engine
That is good to know.
Kind of floating between the T474 and T494 they als list a T494C not sure what this is,
/ Which TYM engine #4
I think TYM now owns Kukje.
/ Which TYM engine #5
Yes, Kukje owned Branson and TYM bought them both.
The C is just the model with a cab.
I'm no expert, but I have been looking in the same range. The comparison would be better between the 494 (Kukje) and 454 (Yanmar). These are basically the same frame (series 4) with different engines and transmission options.
The 474 is a series 3. It is not only a smaller frame, but has fewer bells and whistles.
All of these can be had with or without cabs and with Shuttle or HST transmissions.
/ Which TYM engine #6
Get the T494 if ya can swing it and have room. It lifts almost 700# more on FEL and 1000# more on 3 point than the T474, it is a frame size up. The Kukje A2300N4 is a REALLY sweet engine, it is way more quiet than any Yanmar (Though not a bad engine). And just sounds more refined overall, and being IDI (Indirect Injection) low tech is a plus in my book.
/ Which TYM engine #7
Which is an Onan designed diesel engine, that Cummins got when they bought Onan, so now it's called a Cummins.
SR
/ Which TYM engine
The only question I have between the 494C and the 454C is the 454C seems to list a higher hydraulic flow. Almost 2 gal a minute.
While lift capacity at 24" is only 112 lbs. different.
Pump typeDual Gear PumpDual Gear PumpDual Gear Pump
Implement flow7.66 gpm9.5 gpm9.5 gpm
Steering flow4.25 gpm4.57 gpm4.57 gpm
Total flow11.91 gpm14.07 gpm14.07 gpm
Category, 3-point hitchIII
Hitch lift capacity3822 lb3314 lb3314 lb
Hitch lift capacity at 24 inches behind link ends3057 lb2945 lb2945 lb
Lift control typePosition/DraftPosition/DraftPosition/Draft
No. of standard remote valves222
/ Which TYM engine #9
Lift capacity has nothing to do with hydraulic flow...
Larger flow makes things happen faster.
SR
/ Which TYM engine
Sorry, I am well aware they do not affect one another.
I am still weighing options.
And was simply pointing out some minor differences I had noted.
/ Which TYM engine #11
Not sure if it matters much for your application but the loader (TX57) on the T494 lifts about 310 lbs more than the loader (TX55) on the T454.
/ Which TYM engine
Did not catch that. The only way it won't matter is if the money difference is significant. After working about a1000 hrs OT this year, I am splerging
2011 Kenworth T300 S/A 18ft. Cab and Chassis Truck (A64194)
2011 Kenworth T300...
Eagle Weather Vane (A64557)
Eagle Weather Vane...
2005 Subaru Outback Wagon (A64557)
2005 Subaru...
1995 Bulk 307 SS Insulated 6,500 Gallon T/A Chemical Tanker Trailer (A64194)
1995 Bulk 307 SS...
2021 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2021 CATERPILLAR...
12V YARD SPRAYER (A64278)
12V YARD SPRAYER...
