Pumping sewer into a septic tank. Bad idea?
/ Pumping sewer into a septic tank. Bad idea? #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
I’m working on a on a job now where a house is being built and they want to use an existing system. They planned on doing this from the start and the existing system was designed and permitted for the load so no problems there. But there’s not enough fall to gravity drain it. I’ve done sewer pumps before but they either pumped effluent into a leech field or they pumped raw sewer into a city sewer. I’ve never pumped raw sewer into a septic tank before. So the reason for concern is will a sudden surge of say 20-50 gallons into the tank at one time cause any problems into the septic tank?
/ Pumping sewer into a septic tank. Bad idea? #2
Can you do it in smaller amounts over a few days? If so that would mimic actual use.
  • Good Post
Reactions: JWR
I could make the dosing cycle whatever I want but the smaller it is the more frequently the pump will cycle.
/ Pumping sewer into a septic tank. Bad idea? #4
20 - 50 gallons at a time into a 1000 gallon or bigger tank is not going to cause an issue. Lots of houses have basement bathrooms and laundry rooms with grinder pumps pumping up to a septic tank.
I haven’t looked at the original build specs but it was permitted for 4 bedrooms. So it’ll be minimum 1000 gallons.
/ Pumping sewer into a septic tank. Bad idea? #6
My dosed septic for 3 bedrooms is 75gal 4 times a day. SOrry I thought you meant a 1 time drain of 20-50 gal.
/ Pumping sewer into a septic tank. Bad idea? #7
My tub holds just under 80 gallons to the overflow. After 23 years on a septic system we have never had a problem. I have also periodically dumped 40 gallons of sewage from an RV without issue.
But that’s pumping effluent into a leech field isn’t it?
/ Pumping sewer into a septic tank. Bad idea? #9
Good question 👍
Are you gravity to a pump vault then forced to the existing tank? A 300 gallon (?) pump vault would keep the pump outside and be able to act as a "buffer" during heavy use times.
I've never worked on something like this, but as I remember, there's a good bit of floats and alarms involved so that a (****ty) problem in the house doesn't occur. Does your town or county have requirements (advice) for this set up?
Good question
Yes that’s how it’ll work. The local septic inspector is incredibly unhelpful.
(20) 2.5cm X2M Ratchet Straps (A60463)
(20) 2.5cm X2M...
(3) Good Year 480/80R38 Tires w/ Rims (A60463)
(3) Good Year...
BOX BLADE (A58214)
BOX BLADE (A58214)
2014 Aerway Aerator (A55973)
2014 Aerway...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2016 Homemade 7'X20' Trailer w/Ramps (A60462)
2016 Homemade...
