What is this sound?
/ What is this sound? #1
mahindra1626
mahindra 1626
I am still new to this. I have less than 100 hours on my 1626. When turning the key I get this sound. Wasn't certain if I should be concerned. In the past I thought the sound was slower.
/ What is this sound? #3
Sounds like either a shut off solenoid that's taking awhile to engage or a fuel pump running dry 'till it primes, doesn't sound good either way. I'm guessing fuel pump prime, just a WAG on my part tho..........Mike
/ What is this sound? #5
I have some sort of pump or vacuum that runs for 30 seconds after I shut my tractor off. It does it everytime so I'm assuming it should. I haven't asked what it is yet.
/ What is this sound? #6
The second click is the relay going to warming glow plugs. That is much slower than what your sound is. The constant click is a fuel solenoid switch.
You need to check 5 things.
1. Principal ground wire connection going from battery to chassis.
2. Battery connections.
3. Glow plug rail nuts which reside along the valve cover to make sure none are loose.
4. Glow plug ground connection at end of glow plug rail to make sure connection is viable..
5. Starter solenoid connections.
Thank you!
I was trying to troubleshoot the last few days and was starting to reach a conclusion that I had a loose wire somewhere because the issue resolved itself for a while and just started back up.
Hey thank you everyone,
Had a poor main ground from battery to frame resulting in low voltage causing the glow plug controller to have a rapid click.
/ What is this sound? #9
Thanks for your feed back. That factor is what helps everyone. Wish more people did that instead of simply "disappearing" and breakdown causations remaining a mystery..
/ What is this sound? #10
I'm with you. I hate those hit and run questioners. Especially those who are either too lazy or too ignorant on researching subjects.
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
2001 FREIGHTLINER FLD120 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2001 FREIGHTLINER...
2020 BOBCAT T770 SKID STEER (A65053)
2020 BOBCAT T770...
2016 John Deere 6155R (A64119)
2016 John Deere...
2015 MCLENDON HITCH TRAILER (A64278)
2015 MCLENDON...
