B2150 4x4, motor won't turn
   / B2150 4x4, motor won't turn
If you have it in neutral, will it roll freely if pushed - confirms transmission/ drivetrain not locked up (hard to do if loader is down!).
Still in neutral, can you turn the crankshaft from the front of the engine using a breaker bar and socket - confirms engine not locked up.
Can't really roll it but jacked up rear end and everything spin in gear and out. Can not turn engine manually.
   / B2150 4x4, motor won't turn #12
does it have a clutch? if you engage does the motor then spin?
   / B2150 4x4, motor won't turn #13
youtube might shed some light.
   / B2150 4x4, motor won't turn #16
pull the starter, after that pull the injectors, after that, the oil pan, then the engine...
I pulled starter, and injectors. Started fine in the morning to raise bucket and ran great the whole day prior.
   / B2150 4x4, motor won't turn #18
yea buddy i got nothing for you, if the clutch is in, and the pto's are off, starter is pulled and injectors pulled. you have some sort of mechanical problem, drain oil see if you have metal. I can't think of anything else, is the hydro chain? maybe break a hydro line open
   / B2150 4x4, motor won't turn #19
Only a couple things that I know of that will lock an engine besides a transmission issue which can be eliminated by pushing in the clutch or putting in neutral aid that is a dropped valve, hydrolocked engine or ran it out of oil and spun a bearing.
   / B2150 4x4, motor won't turn #20
Have you ever had the overhead adjusted. I believe Kubota recommend every 1000 hours or so. Pull the valve cover and have a look-see at the valves.
18' X 20' STORAGE GARAGE TYPE CARPORT BUILDING (A52708)
18' X 20' STORAGE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
JCB Forks and Frame Skid Steer Attachment (A56857)
JCB Forks and...
Mini -Excavator Heavy Duty Rock Ripper (New/Unused) (A59225)
Mini -Excavator...
