Username Taken
- Joined
- Jan 4, 2019
- Messages
- 1,030
- Location
- S Florida Winter/Michigan Summer
- Tractor
- Kioti CX2510 HST
I suspect the driver lost his brakes long before the accident. Probably heated them up to the point of non-functioning coming down that grade.So if published reports are all fake news, the truck weighs 19k lbs, and the boat weighs only 19k lbs the guy was 'within the truck's tow rating' and shouldn't need trailer brakes? Who would expect otherwise and blame the size of the load, esp behind an F350 duallie?
btw, when a trailer of wood pushes a tractor down a hill, why don't more operators just ease into the brush to slow down or out onto a field to not jack-knife the whole bit?
"Survey says" just because the brakes didn't work anyone should still be able to steer off the road, like we'd have done by reflex. Heck, this guy could have had a whole ten seconds to realize what we see as obvious in the wisdom of not being there.
I also suspect the trailer brakes went first. Probably drum brakes. And then the TV (tow vehicle) brakes started to fade. Fast. Which is why I think I see smoke coming from the rear brake. The rear brakes will go last.
