Looking for general info on Bendix, starter, switch, solenoid.
   / Looking for general info on Bendix, starter, switch, solenoid. #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
This is on a K-Mule that has given no problems. Have put a new battery in it. Turn ignition key and nothing happens, no click or light dimming, nothing! Jump across the solenoid and the starter motor runs but does not engage the engine. Looks as if we have a ignition switch problem and a Bendix problem. Why the sudden problem? What say you?
Thanks
   / Looking for general info on Bendix, starter, switch, solenoid. #2
Maybe starter switch has more than one connection to starter and solenoid?
I like to fix the known problems first, looks like switch , but have you checked grounds to make sure juice is getting through?
   / Looking for general info on Bendix, starter, switch, solenoid. #3
Clean battery terminals and connectors on cables. Replace cables and tighten securely. If you can move them they're not secure. Follow ground wire to frame. Clean and tighten. Charge the battery and try it again. This may not fix your problem but it's always a good starting point.
   / Looking for general info on Bendix, starter, switch, solenoid. #4
Is your terminal orientation correct? If the poles are reversed, as a starter is DC it will run backwards- but of course the gear can't travel and engage.
   / Looking for general info on Bendix, starter, switch, solenoid. #5
More info on your K Mule. Year and model please. I had a 1996 2510, bought new. Up graded in 2020 and gave it to my daughter. Several batteries, but original starter.
2019 Mule SX XC
We are starting at the top and have a new ignition switch ordered. Stay tuned.
Bill
New switch didn't help, so we have a new solenoid ordered.
   / Looking for general info on Bendix, starter, switch, solenoid. #8
It may be the solenoid. That type starter uses a lever from the solenoid to the "bendix"/one way clutch. If not the solenoid, maybe, lever system is stuck/jambed?
Zebrafive, Thank you! You can jump the solenoid and it turns but doesn't engage the motor. With the key ignition switch it does nothing, no click or anything. If this doesn't work, it looks like a new starter.
   / Looking for general info on Bendix, starter, switch, solenoid. #10
It could be the "Bendix" The internal one-way clutch may be bad, so shaft spins, but does not spin the gear.
2014 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2014 MACK GU813...
2000 John Deere 770CH Articulated Motor Grader (A49461)
2000 John Deere...
1996 Lincoln Town Car Sedan (A50324)
1996 Lincoln Town...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2014 Doosan DA30 (A51039)
2014 Doosan DA30...
