MT225s Loader Valve Leak
/ MT225s Loader Valve Leak #1
wraven
Member
South Central Pennsylvania
LS MT225S and a Huskee that identifies as a CASE Magnum 240
I developed a leak at the bottom of my MT225s loader valve. Bolts are tight and it leaks when operating the bucket.
I am assuming it is some type of pressure valve. Can anyone tell me what this part pointed out with the arrow is called. I don’t know if there is a gasket I can replace or what.
None of my manuals have a parts breakdown for this.
Happy Thanksgiving !
/ MT225s Loader Valve Leak #2
WOW.....My 2021 MT225S blew 2 o-rings at the TOP of the same valve ( dealer said the nuts were not lock-tighter down)....$500 bucks to send it to the dealer who "fixed" it. However...just last week it blew AGAIN. Now the dealer is going to replace the entire valve. I seem to think it has to do with the "floater" operation.
I wasn’t even thinking about warranty work. I’ll be calling my dealer in the morning.
I didn’t read my work email until today but my dealer replied on Friday. He will be ordering a replacement valve on Monday.
Availability is another matter in these times we are living but I have nothing but great things to say about Barlow Ag in Gettysburg PA!
/ MT225s Loader Valve Leak #5
My dealer got the entire valve in las week....he three dated it....now just waiting for the dealer to come and pick up the tractor.
/ MT225s Loader Valve Leak #6
My MT225S developed the same upper valve leak, just the other day. I was back-dragging some woodchips using the float position. No load on the bucket of note. Just started a steady drip-drip-drip while there was hydraulic pressure in the system.
Mine is leaking from the red circle area and pooling/dripping at the green circle.
/ MT225s Loader Valve Leak #7
My tractor is in for its 50hr inspection. The dealership is telling me everything is complete but they are waiting on a replacement loader control valve. It's already been a month so hoping they get a replacement before snow arrives. Warranty item. Not sure how/why it started leaking? I really haven't put any heavy use on the bucket.
/ MT225s Loader Valve Leak #8
Would you mind posting a few more pictures of the top of your valve? I think you have a new design...the top of my spindle keeps snapping off.
/ MT225s Loader Valve Leak #9
Interesting my 225 broke the same way with that silly mouse trap,the linkage loads the valve on the side causing the breakage. Mine was replaced under warranty, now just about a year after the replacment fluids poring from the top of the same valve more than likely do to the side pressure applied to the valve when going to the flote position. My dealer apparently had never seen this valve break like this, his story I don't but it. Anyone else?
/ MT225s Loader Valve Leak #10
Just for future reference , mine also broke at the same place. But unfortunately is not under warranty, I'm in the process of looking after the part cause the controller is cad$1k. Or I'll try to get someone to weld it.
/ MT225s Loader Valve Leak #11
That valve that controls the "float" function on mine quit working. Parts were astronomically high so I've been living with it this way. Love the LS/New Holland tractor but the FEL has been complete trash since day 1.
/ MT225s Loader Valve Leak #12
Bump this to the top here as I have my bucket control valve leaking now. I took it apart and the O-ring is blown out of what I would call a spool valve. Does anyone know what size O-ring this valve takes? I have tried a few different ones but they blow out after a few hours. * Picture is from another thread but that is the same O-ring that I need.
Thanks
/ MT225s Loader Valve Leak #13
Any update on a fix for this? I started having the same issue the other day. I found some O-rings at Tractor Supply that appeared to be exact matches, but after and hour or so they start leaking
