2017 xr4150 tractor limps/dies codes f3,f4, f11, f31
   / 2017 xr4150 tractor limps/dies codes f3,f4, f11, f31 #1
oldestgoat
new holland tc33da/ LS xr4150, Ford 1620
Really? This thing has only 230 hours. Was cutting grass today and it all of a sudden throttled down. Hard to start and dies. limp mode? From research here looks like it might be something to do with the throttle pedal sensors. Any insight would be appreciated. Thanks!
   / 2017 xr4150 tractor limps/dies codes f3,f4, f11, f31 #2
I had an issue like this. It was warrantyed with a month left. It was the hand throttle not talking to the foot throttle.
Do you have the parts breakdown and error code Ebook ?
   / 2017 xr4150 tractor limps/dies codes f3,f4, f11, f31 #3
Could always be something simple like bad fuel too, that's easily remedied.
   / 2017 xr4150 tractor limps/dies codes f3,f4, f11, f31 #4
Should be an 'S' Code along with the F code. Did you see anything like S137 F31?
Also, looking in the service manual for your tractor, F3 and F4 does not seem to exist.
Do you have an OBD2 reader? Its not terribly helpful, but can help in many instances.
I had a similar issue that I called the dealer out for. After several hours of troubleshooting, we found a very small rip in the fuel line. So small that it didnt leak fuel, but did suck air. Air in the diesel fuel line means the tractor will behave just like yours. Start with the basics.
   / 2017 xr4150 tractor limps/dies codes f3,f4, f11, f31 #5
I had a very similar problem with mine. Turned out to be the hand throttle as was mentioned previously. My dealer said it has been a common problem. No problems since it was replaced.
   / 2017 xr4150 tractor limps/dies codes f3,f4, f11, f31 #6
Where can I purchase or download this manual?
   / 2017 xr4150 tractor limps/dies codes f3,f4, f11, f31 #9
I shared it.
I'd be cautious about sharing your email on a public forum like this. Each is their own.
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2013 TYTAL CRUDE TRAILER (A58214)
2013 TYTAL CRUDE...
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
2015 FREIGHTLINER M2 TANDEM AXLE 24FT FLATBED (A57880)
2015 FREIGHTLINER...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
