2017 xr4150 tractor limps/dies codes f3,f4, f11, f31
   / 2017 xr4150 tractor limps/dies codes f3,f4, f11, f31 #1
oldestgoat
new holland tc33da/ LS xr4150, Ford 1620
Really? This thing has only 230 hours. Was cutting grass today and it all of a sudden throttled down. Hard to start and dies. limp mode? From research here looks like it might be something to do with the throttle pedal sensors. Any insight would be appreciated. Thanks!
   / 2017 xr4150 tractor limps/dies codes f3,f4, f11, f31 #2
I had an issue like this. It was warrantyed with a month left. It was the hand throttle not talking to the foot throttle.
Do you have the parts breakdown and error code Ebook ?
   / 2017 xr4150 tractor limps/dies codes f3,f4, f11, f31 #3
Could always be something simple like bad fuel too, that's easily remedied.
   / 2017 xr4150 tractor limps/dies codes f3,f4, f11, f31 #4
Should be an 'S' Code along with the F code. Did you see anything like S137 F31?
Also, looking in the service manual for your tractor, F3 and F4 does not seem to exist.
Do you have an OBD2 reader? Its not terribly helpful, but can help in many instances.
I had a similar issue that I called the dealer out for. After several hours of troubleshooting, we found a very small rip in the fuel line. So small that it didnt leak fuel, but did suck air. Air in the diesel fuel line means the tractor will behave just like yours. Start with the basics.
   / 2017 xr4150 tractor limps/dies codes f3,f4, f11, f31 #5
I had a very similar problem with mine. Turned out to be the hand throttle as was mentioned previously. My dealer said it has been a common problem. No problems since it was replaced.
   / 2017 xr4150 tractor limps/dies codes f3,f4, f11, f31 #6
Where can I purchase or download this manual?
   / 2017 xr4150 tractor limps/dies codes f3,f4, f11, f31 #9
I shared it.
I'd be cautious about sharing your email on a public forum like this. Each is their own.
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
2004 GMC Sierra 3500 (A55973)
2004 GMC Sierra...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
2001  WABASH 53FT DRY VAN TRAILER (A57880)
2001 WABASH 53FT...
2011 Ford Escape XLT SUV (A54815)
2011 Ford Escape...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
