Please weigh in on a weighty issue.
   / Please weigh in on a weighty issue. #11
I was wondering too on the estimated weights.
900-1000# bale's for a 5x6 don't sound right.
My neighbor makes 5x6 bale's. He has a skidloader and a 100hp New Holland. He estimates them at 1500-1600.
One of these days I'm gonna take the MX over there just to see if it will handle one, how high it will lift, various ballast weights, etc. Just so I can be a little more informative on posts like these.
1500# is doable on a pallet with forks on a MX. But bale's stick out there a little more
Thanks for the replies so far. To clear up some questions, he will probably only handle a bale a week or less. And a muddy feed lot is not an issue. Being able to drop a bale into a round feeder and stacking in a barn are considerations. Thanks again.
   / Please weigh in on a weighty issue. #13
Picture from 2010, took this load to the scale at the Co-op. 5x6 bales averaged 1450 pounds each:
   / Please weigh in on a weighty issue. #14
HP really isn’t the classification you want to be using. There’s a wide variation is sizes for the same HP tractor. Also how the tractor is setup makes a big difference. You could do the same job with a 50 percent smaller tractor if it had optimal ballast. It seems that most farmers want to use a 100 hp tractor with no ballast to do the job.
   / Please weigh in on a weighty issue. #15
I moved round bales with my TC40DA with no issues. Moving them out of the field I had forks front and rear. Load the rear first for ballast. When moving them to feed I always had rear ballast from the arena drag. Just go slow and kept it low to the ground until I lifted it up to drop in the feeder.
   / Please weigh in on a weighty issue. #16
A 45 horse tractor will handle all he wants. I’ve got a 45 and I move 4x5 and 5x5 bales frequently. Bahai bales. Bermuda bales. Rye and some with clover. Clover makes a heavy bale. I’ve not run into any issues yet and I don’t use a ballast. Just loaded rear tires. I do recommend getting a true bale spear and not a clamp on bucket type.
Note: I live on rolling hills
   / Please weigh in on a weighty issue. #17
What is your 45 HP tractor.
John Deere makes a 3046r. Doubt it would handle a 5x6 bale blasted and no chance at all non ballasted.
Deere also makes a 5045 that would likely handle it day in and day out.
Simply saying a 45 HP tractor will handle all he wants is the WRONG way to size a tractor for moving big round bales. I can point you to a tractor that is 45hp yet weighs UNDER 3000 pounds. I can also show you one that weighs double that
   / Please weigh in on a weighty issue. #18
It’s a kioti dk4510. I didn’t say anything about a 5x6 bale. Not sure my would handle a 5x6 safely. I know I could move it but not safe. I assume the guy knows something about tractors since he’s needing it for hay. But I may be wrong in that assumption.
   / Please weigh in on a weighty issue. #19
You said a 45hp tractor will handle all the op wants. And the op wants to handle 5x6 bale's......
   / Please weigh in on a weighty issue. #20
Perhaps one more thing to look at as far as longevity of the rear axle and the 3 point. Most of the 40ish HP tractor come with cat-1 3 point and a an axle matching that. My MX-4700 comes with cat-2, 3 point and a lot beefier axle in comparison to a mid 40ish kubota (L series) with cat-1 and not as beefy of axle. Along with that My Kubota has a sub mount for the loader that ties the bell housing to the rear axle that I think is pretty important for stiffness of the tractor loader and rear end combination for picking up hay bale on both frontand the rear of the tractor.
2010 BMW 328i (A56859)
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
HAMM H11 PADFOOT ROLLER (A58214)
HAMM H11 PADFOOT...
2020 MACK P164T (A58214)
2020 MACK P164T...
JOHN DEERE 630 DISC HARROW (A52708)
JOHN DEERE 630...
