1301d vs 226d
/ 1301d vs 226d #1
Ducman
Yanmar 1301d
I have a 1301d that I am a bit disappointed in. It seems too small to scoop up dirt/gravel.
I am looking at a 226d 4x4 that I am hoping will serve this task better as well as field mowing and tilling. I would appreciate any feedback as well as things to look out for. Thanks!
/ 1301d vs 226d #2
See my sig photo below. I have Yanmars similar to both of those. Loaders on both.
The YM240 will do anything you described but as a manual transmission, its a nuisance to never be in the right gear for the various slopes in my orchard. Full stop, shift, run 100 ft, full stop, shift .....
Then I bought the YM186D for its lower height (orchard) and PowerShift. It's a little underpowered for tilling, and for mowing going up a slope, but I use it 90% of the time and have dedicated the YM240 to carrying the backhoe and occasional heavier lifting.
These aren't perfect comparisons to what you are asking but a 1301 to me seems a little too small for my applications - till, mow, pull a one ton watering trailer, grade the lane, occasionally put forks on the loader bucket to unload something. Seems to me a 1301 is better suited to a big vegetable garden, or grounds maintenance, instead of these heavier tasks. While YM1510D/YM186D is the smallest 'real tractor' that you just use without thinking about it.
I looked at Tractordata .com. Ym226D and YM240D are near identical in specs, maybe 1 hp difference. So essentially identical.
Hmm. I should get one 226D to replace my fleet.
Good luck in your search.
/ 1301d vs 226d #3
Did the same with an upgrade. "Garden Tractor" in a couple yrs. it was showing wear. My Ym2000/240 was right at the same as the old N series fords. I can't be exact since our 9n was upgraded to a 6Cyl.. The org. 9n was 22Hp. and the 8n. 30hp.. Don't hold me to exact specs. but my Ym2000 24Hp. Just smaller which was a big plus. Plain jane as it can be but still use it to the day.
/ 1301d vs 226d #4
It wouldn't expect much from a YM1301. It's a true SCUT (SUB-Compact Utility Tractor). With your needs, a real CUT (Compact Utility Tractor) is ideal.
Keep with a 3-cly diesel as a minimum. And a YM2310 model as a minimum.
The YM226D 3-cly and a tiller is somewhat questionable. Ideally the YM276 shines with a tiller.
The 3T75HA is not as strong as any of the 3T80 or 3T84 engines that do great tiller work here in North America.
The YM226 would be just fine for mowing.
/ 1301d vs 226d #5
The one difference is weight. Ballasted up an N will weight 2x what a ym2000 will weigh which it was designed to pull ground engaging equipment in row crop operations and that weight will allow it to out pull out Yanmars. But we probably can outperform an N with the torque and effeciency of the 24hp diesel. I'm thinking an 8n was like 26ish HP? But close enough we're in that 25 to 30 range.
/ 1301d vs 226d #6
To the OP I think the 226 will perform what you want better than the smaller 1300 which is more of a tilling tractor.
/ 1301d vs 226d #7
YM2000/YM240 vs Ford 8N. They seem similar but the 8N with more torque and weight should out-pull the Yanmar.
Figures from TractorData:
Ford 8N
Ford 2.0L 4-cyl gasoline
Torque: 92 lb-ft @ 1500
Fuel use: 2.5 gal/hour
Weight: 2410 to 2717 pounds
Drawbar (tested): 21.95 hp
PTO (tested): 23.24 hp
__________________________
Yanmar YM240
Yanmar 1.1L 2-cyl diesel
Torque: 46.9 lb-ft@ 1800
Fuel use: 1.3 gal/hour
Weight: 1698 to 1931 pounds
Drawbar (tested): 16.54 hp
PTO (tested): 19.76 hp
/ 1301d vs 226d #8
Ford 8N
Yanmar YM240
Good stats. My YM2610 sips fuel way better than the neighbors 8N gasser. We had done a property line project we both worked on together. He had to refill his machine 2X and I kept going. :) The 2 machines are nearly evenly weight too.
The stats of a JD850 to an 8N would be the gem here.
/ 1301d vs 226d #9
My boss when he lived in the country had a JD1020 which was a 60s era JD row crop tractor. I believe it's in the 30hp range. He basically 99% finish mower his yard with it, once a week, now that was like 6 or 7 acres of grass but if I remember right he used something crazy like 10 to 20 gallons a time to mow. When I was talking to him about it and he asked about my tractor. I said I'd probably use a little over a tank of fuel to cut what you cut. And he said how big is your tank. I said 5 gallons! I said yes it will sip fuel.
/ 1301d vs 226d #10
I was stated don't hold me to exact specs.. Said there was a size difference and know can't use Tractor data to be 100% correct. Example my Ym2000 is rated more than 20 HP. Eng..which they have it rated. Twice so it's not a Typo. There was a Piston upgrade 88mm. to 90mm. and only 2 cyl. I don't think that will build 2 more Eng.Hp. each cyl.. Fredricks and Hoye 24hp. Hard for me to lift a full 5 gallon can filling the tank so I purchased a 2 gal. can Yrs. ago. I cut 3 acres Wkly. My use is so small it's hard today to guess just how much fuel I use cutting. My guessstimate 1/4-3/8 of a Gal. each cut. My sears garden tractor was twice that much in gas. True!!......
/ 1301d vs 226d #11
Yeah but ... The HP I found in TractorData for PTO output, and the drawbar pull, came from field testing performed by U-Nebraska Ag school.
Nebraska Tractor Test Laboratory | Nebraska
Maybe YM2000/YM240 is more comparable to the early N's. 9N from 1939, and the 2N's. 8N was a HP improvement, no?
/ 1301d vs 226d #12
I wasn't trying to say your wrong just throw in what I recalled as the power outputs. I didn't look it up either, just from what I recalled. If tractor Data says engine HP is 20 someone screwed up. That is 20 PTO HP. And we all know the 24 HP engine number for the YM2000/YM240 cause the data plate says so. Not sure who put that into tractor data. Haha
/ 1301d vs 226d #13
The 8N and the YM2500 are a near neck-and-neck. YM2500 = JD850. I toss in the YM2610 because the difference is add in the PowerShift.
So, the JD850 Nebraska Test data is here on Tractordata.com
/ 1301d vs 226d #14
Tractordata just goes by OE documents submitted to them. But yes, even those documents can be done wrong.
Besides, the gray market Hp is in JIS standards and not SAE Hp standards. Thus, the Hp can be off by as much as 5 to 6Hp numbers. So, when Tractordata lists Hp for anything Gray Market, note that the Hp could be higher in reality to the SAE standards.
/ 1301d vs 226d #15
SAE hp is a naked engine on a test stand. No alternator, fan, maybe even no water pump driven. Yanmar's published hp is measured as the PTO output.
/ 1301d vs 226d #16
And the Hp curves are based on the JIS standards for Yanmar. I've spend a few hours looking into this already. SAE and JIS are not even close to each other. So, those Nebraska tests on gray market machines are really helpful. And in my case, the JD850 is the YM2500, the Neb. tests there prove the point.
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
GOLF CART FRAME & CAMPER/RV WINOWS & SHELL (A62131)
GOLF CART FRAME &...
2007 International 4300 Altec DM47 TR 47ft Insulated Digger Derrick Truck (A60352)
2007 International...
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
SPEECO QUICK HITCH (A62130)
SPEECO QUICK HITCH...
Ford Pickup Truck Bed (A61568)
Ford Pickup Truck...
