The right tractor for towing/forestry work
/ The right tractor for towing/forestry work #1
antryan
Can-am
Hi,
I haven't really posted on this forum but have spoken to several of you by pm, soaking in all the wisdom that i can. I am considering purchasing a tractor with the primary purpose of towing a log loader and doing forestry work. Up until this year I've been reluctant on investing in a tractor primarily because of the maintenance requirements. I think the right tool for the right job approach is something had focused on, leaning towards frugal options.
Currently for basic skidding and yard work I've had relied other off road vehicles, which to my surprise is meeting all but one my requirements. Some logging work, specifically loading heavy 24"+ dia trees, has become a challenge and while I could manage I wanted to invest in something that made it easier. This year I bought a used log loader, a Metavic 1400 loader with 18RF trailer and started looking at the best towing options. I will be primarily using off road trails with some steep and hilly terrain, mildly hard soil (clay like), on mostly forest populated land. As such I need something that can tow this heavy trailer up/down hills and not fall apart. I have focused on identifying tractors that provide stability and power for the work, and quickly realized there is a lot to consider. With the hills, I felt full body steel frame tractors with 4WD would be best. I don't plan on loading the trailer up to its max capacity and will likely load a minimal amount on most trips.
I found a used 2006 Mahindra 4530 4WD w/o a loader available that seems to check all the boxes with exception to towing capacity, which I understand isn't something normally included on manufacturer specifications. The engine has 42hp and has less than 900 hours on it. I've done some basic research and understand there may be some issues which the tractor could have.
I am planning on down grading the trailer, moving the loader over to the new trailer to reduce the total weight
Current estimated log loader weight- Metavic 1400 + Metavic 18RF: 4125lb (18500 payload)
Future estimated log loader weight- Metavic 1400 + Metavic 17RF: 3225lb (14000 payload)
Is there a way to tell if the tractor I am considering would have enough towing capacity? Are there alternative vehicles (tractors) that I should consider - eg, a skid loader vs compact?
I appreciate any suggestions. Thanks!
/ The right tractor for towing/forestry work #2
It’ll pull it fine but stopping isn’t a tractors strong point. Does the wagon have brakes?
/ The right tractor for towing/forestry work #4
Tractors generally list towing hitch capacity in the specs or owners manual.
I would suggest something with 4WD braking and AG (R1) tires to dig in. You’ll need stopping power.
My Case IH is equipped with hydraulic brakes for the trailer and my Massey Ferguson is equipped with air brakes for trailering.
Not sure if smaller tractors have that option or your trailer can be equipped with brakes.
/ The right tractor for towing/forestry work #5
Three Point Hitch tractors are designed to PULL. I speculate that almost all 4-WD compact tractors with R1/ag tires filled with liquid can pull a trailer at least 3 X their bare tractor weight specification.
Consider (hard) foam filled tires if you will be in the woods 200 engine hours per year or more. Punctures and rolling tires off the rims are real possibilities in woods work. I have experienced both misfortunes.
I do a lot of woods work in terms of property maintenance involving transportation of fallen mature Oaks and Pines to a community burn pile. I pull timber with chains. I have no experience with specialized logging equipment nor logging.
Have you researched log skidding winches, which I think would be almost mandatory for your applications?
VIDEO:
Mahindra 4530 Dimensions​
Mahindra 4530 tractor photo
2005 - 2020
Model year 2005-20082010-2020
30 Series
Utility tractor
Dimensions Length:134 inches
340 cm
Width: 72.5 inches
184 cm
Weight: 5567 lbs
2525 kg
A skid loader or compact track loader are designed to push and lift, not pull. Both variants are likely to be much more costly than a tractor of equivalent towing capacity. Tracked equipment is very stable and has low ground pressure but tracks are maintenance intensive relative to wheels.
VIDEO:
Valtra (brand) tractors from Finland and Brazil are used as much in forestry work as ag work. Note the bulbous tires, probably radials, for float in bogs. Florida uses some Valtra tractors for highway right-of-way mowing.
VIDEOS: valtra forestry tractors
/ The right tractor for towing/forestry work #6
You mention hills. But "hills" are different to everyone. Hills to someone in kansas are gonna be alot different than hills to someone in wyoming. And you give no indication of where you are from.
Are you wanting just a bare tractor? Or are you wanting something with a loader to also be able to grapple and move the logs.
I have a MX5100....which is a bit lighter than the bare tractor 4530 you mention....however with loader, grapple, and ballast I am sitting at north of 7000lbs with 50+ engine HP.
Pulling and towing are not the issue. I regularly haul my dump trailer with logs....estimated about 3.2k trailer and about 8k payload. A little north of 10k. It handles it fine.....but sure wouldnt want to do that up and down steeper hills. That much weight will push a tractor around.
You are now talking about double the weight. I think if I was gonna do that on a regular basis....Id be looking for something that is around 8,000-10,000 pounds ballasted out to not let the trailer control you. That would likely put you somewhere around a 7000-8000 pound bare tractor and 70-80hp
/ The right tractor for towing/forestry work #7
I also question a trailer WITH a log loader capable of a 14k payload and the whole thing only weighs 3200#?
Perhaps a picture of log trailer/loader would better help get a visual of just what you want to tow.
IF it wasnt for "hills" which is yet to be defined.....I'd say you could get by with half the weight of what my previous post suggests.
There is a reason why even the smallest actual log skidders are near 20,000 pounds
/ The right tractor for towing/forestry work #8
The metavic website suggests tractor sizes for their loaders Or am I missing something here?
/ The right tractor for towing/forestry work #10
Consider at least 60 HP, loader, 4x4, HST and some gnarly woods chains. Wet clay may be slippery. HST should give better traction control.
You may also want to look at a log winch for those areas you cannot access with the trailer.
Some pictures of log gathering equipment.
/ The right tractor for towing/forestry work #11
Hi,
One thing I would suggest is to look under the tractor you are looking to buy and see what kind of underside protection there is. What could be damaged? Torn off?
Look at the maximum width you want to maneuver within the trees. If you keep the bucket on the front that will usually be your widest point.
If you have to have a cab tractor might want to look at a forestry protection cage around the cab.
Lastly consider the total weight of your tractor/implement. I rented a skid steer and with the front rotary cutter I had about 12,000 lbs. Within 2 hrs of doing work within my trees, I sunk the skid steer up to the treads.
/ The right tractor for towing/forestry work #12
I ran a material dump trailer behind my NX5510 (55hp). Trailer weight 3k lbs (empty). It had surge brakes, so no worry about being pushed around: I could feel a bit of push, but if push came to shove the trailer's brakes should operate. I was operating in the higher end of load capacity, 10k to 12k, but no significant grades (other than departing from property where I was fetching the material from; pulling up a bit up on to the roadway, which had a slight upward grade, felt like an elephant coming out of a snow bank). Probably a good 130 runs in all: which should garner me more than novice status on such matters. Problem with surge brakes is that they don't work in reverse, in which case it's not a good idea to back down a hill (lest the tail run off with the dog)!
Rough terrain, uneven, hills and a lot of weight with a CUT isn't a good combo. No real room for error. Stuff is going to break, and this is going to imperil the operator.
If one can batch up the work then it would be recommended to then rent the appropriate equipment to do the particular work/task. By "batch up" I mean scheduling of [like] work to be done (be done in a given period- not ad hoc).
/ The right tractor for towing/forestry work #13
I've experienced that sinking feeling! I once sank a 9k lb, rented, excavator. But, renting is still the best way to go if one cannot afford industrial-level equipment for use in nasty situations/environments. Such equipment is armored up: other than getting stuck, getting into brush isn't going to bust stuff up like can happen with a CUT. Bust your CUT and it can be more expensive to repair than the cost of renting equipment: do this more than once and, well, shame on you!
/ The right tractor for towing/forestry work #14
In my country, it's very common to see tractors pulling log cranes and log trailers. Even driving on the road with a full load. Also, in Europe, the tow ratings of tractors can be found on the spec sheets, both brakes and un-braked.
Some of these trailers have brakes, some don't. Some have hydraulic drive on the trailers, some have mechanical drive, others don't. Some mount the crane on the tractor, others mount the crane on the trailer. There is literally an option for all tastes.
Of course, the tractor and trailer are matched to each other (most of the times) and the operator does need to be aware of the stopping ability of the entire combo and how it will behave. You won't see a tractor much smaller than a large frame 50hp tractor often, however I've seen some 35 HP tractors doing this work as well.
People who do it for a living and can justify the extra expense, will shield the entire bottom of the tractor and also fit R1 Forestry tires. Other tend to run R1 Radial tires.
The bigger loggers will usually run a bigger 150HP+ Valtra tractor with the matched logging trailer.
/ The right tractor for towing/forestry work #15
What are you doing with the logs? Would you do other work with the tractor? It just seems like it would be a mistake to buy a tractor without a loader. You might wish for a grapple and/or forks in the future.
/ The right tractor for towing/forestry work #16
Weight and HP were the reason I upgraded from an L4630 to the M6040.
My main working task besides snow removal was log skidding.
I outfitted it with a grapple fork on the loader and a skidding winch on the 3ph.
I estimate working weight at around 7500 lbs which allows me to haul tree length [70+ ft] logs. with little difficulty.
/ The right tractor for towing/forestry work #17
I think tractor weight is going to be important in your decision. My L4740 is pushing close to 8000 lbs. tractor is 4600 plus 1400 loader plus 1500lbs of ballast in the tires and nothing on the 3pt. I'm pretty sure your working weight on your M6040 is higher than that unless your tires aren't filled. Just realized you may have an open station so you might be close on the weight.
I wouldn't want to be pulling 14000 lbs of logging trailer in the woods. hills and mud will greatly reduce traction. I do have R4 tires with no chains so...
/ The right tractor for towing/forestry work #18
I have to say, the most dangerous piece of equipment in the woods is a farm tractor...... I know it aggravates but they really aren't designed for that use even though you can put all kinds of components on them.
Wow, thanks for all the responses!
@4570Man @oosik @Hay Dude Thanks! It appears the trailer doesn't have the hydraulic break assist feature but that is an option I can get on the next one. I will look and see if air breaks are possible as well.
@DieselBound thanks for added break information. I've never heard of surge breaks but do know the trailer has optional hydraulic break assists. It just appears the one I got might not have that option installed. It doesn't have a PTO shaft or added hydraulic cable aside from those to control the grapple.
@tradosaurus Great point about underbody protection! I've added skid plates on my off road vehicles and those saved me from some damages. I never considered it for a tractor but it makes sense.
@LD1 You are correct. I apologize for the lack of clarity on what I referenced as hills. The contour of the property is moderately steep to steep going from 600ft above sea level to 550ft on one side and from 550ft to 700ft (some 15% slopes) on the other side, essentially in the middle of 3 mountains. 5.6 acres of the parcel is greater than 25% steep slope. I don't plan on taking the tractor close to that 25% slope - and have service trails I am rebuilding to allow some access. I am worried about the tractor sitting on the 8% or 10% slopes while I load. My off road vehicles don't have much of a problem.
I am considering just a bare tractor since I don't have a need for the loader "just now". I would get the loader if it would improve weight or reduce pushing the tractor as you mentioned.
@MossRoad Thanks for the lookup link, Mahindra didn't provide that to me when I called and it seemed as if they really just didn't want to help. Their advice was "contact a dealer"...
@ddbackhoe I missed that, thank you! It looks like I need a much bigger machine.
@ptsg Thanks! I was worried about getting something too small... I wouldn't want to attempt pulling a log trailer with a lawn mower. Those photos were awesome.
@dodge man My current objective is clean up, pulling felled trees out of the forest and salvaging whatever they can be used for. The property hasn't been maintained in atleast 7 years. I would likely do more work with the tractor but primarily the need would be in towing out the trailer. The trailer has a winch to skid up logs next to the trailer and a loader to lift them.
@fruitcakesa Thanks! I think getting a grapple fork loader would be ideal, I just hadn't considered it as an primary need. It appears I need to consider that option. I like the M6040. Do you haul on rough terrain?
/ The right tractor for towing/forestry work #20
Antryan a 40 horse tractor will definitely be way to small for what your wanting to do, more like double the size is what will be needed
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
2016 CHEVROLET SILVERADO 2500HD (A63569)
2016 CHEVROLET...
John Deere TX Gator (A60462)
John Deere TX...
Hydraulic rail grinder (A61307)
Hydraulic rail...
2023 John Deere Z950R Zero Turn (A63116)
2023 John Deere...
