Nice little air tool.
/ Nice little air tool.
I have small compressor which does most of what I need, it just does not have CFM for sustained use of high CFM volume tools....
That tool would probably work for you, as it only takes a few seconds to chamfer a a piece a foot long. I don't know how many CFM it uses, but it worked fine on the lowest speed setting and it worked fine.
/ Nice little air tool. #23
Yeh, should be fine. I got a mini-compressor in my garage, it will run a pneumatic impact gun no problem. The compressor would just cycle more often than it would if it had a bigger tank.
/ Nice little air tool. #24
My point exactly.... Or it will run continuously trying to keep up....
/ Nice little air tool. #25
I suppose it depends how small your small compressor is. Mine doesn't run continuously.
2012 Caterpillar CB54 Articulated Vibratory Tandem Smooth Drum Roller (A61572)
2012 Caterpillar...
2014 KUBOTA SVL75-2 SKID STEER (A64279)
2014 KUBOTA...
MF GC2300 fel replaced
2008 Ford E-450 Super Duty Ambulance (A61573)
2008 Ford E-450...
159116 (A60430)
159116 (A60430)
Generator (A61572)
Generator (A61572)
