Machining metal parts
/ Machining metal parts #21
Metal work is like simple arithmetic:
Add……..welding
subtract……machining
Multiply…….cnc
Divide……….cut off saw
A decent vertical turret Bridgeport type mill and a metal lathe will help with the subtraction.
And once you have a mill your old drill press will become a dust collector.
Lots of good advice above, especially on considering hiring a machinist to inspect a potential mill to purchase, lots of junk out there for sale that I would not put in my shop.
I have two vari speed mills and 1 CNC Hurco. My not so old drill press holds my coffee cup :ROFLMAO:
/ Machining metal parts #22
https://youtube.com/c/Blondihacks has some good intro to machining videos for the lathe & mill. Great place to start.
So many machining things you don't even conceive of until you start learning or doing. Fun like dozens of pounds of mild steel is not nearly stiff enough. Followed by hundreds or even thousands of pounds of cast iron isn't stiff enough. Or everything is a spring no matter how stiff you think it is.
/ Machining metal parts #23
Yeah, my ACRA mill is 3400 lbs. Stiffness and vibration damping are key to accurate machining. The small square column mills can be improved by filling with epoxy granite.
I built the Fitch RPC. Very easy. Single push button to start and push button to stop. Can have a remote start/stop buttons and indicator at each machine, if you like.
/ Machining metal parts #24
These four YouTube channels I found to be very informative.
MrPete222
Frank Hoose
H&W Machine Repair and Rebuilding
Joe Pieczynski
I started out on the journey u are about to begin roughly six years ago and I’ve enjoyed every minute. Here are some thoughts:
A mill and a lathe are complementary to each other. Each has certain tasks it does very well and each can do tasks the other does but not quite as easily.
A digital read out (DRO) on both the Mill and the Lathe reduces the effort required to keep track of tool position and makes your work go faster.
My shop space (single car garage) is limited. I had difficulty finding an American made small lathe that wasn’t beat to death. My solution was to buy a Precision Matthews (Chinese) 12” lathe. I couldn’t be happier.
If you can find a Bridgeport mill in decent condition (and can afford it) buy it. I looked at several that were in miserable condition and several more that were nice but the asking prices were so far above my budget I couldn’t begin to negotiate. I ended up getting a circa 1980’s Taiwan clone.
As far as spindle tapers, for the mill I don’t think it really matters what u get. If the mill you buy lacks tool holders, eBay has plenty of tool holders at reasonable prices for just about any taper. For the lathe, you only need to understand that a threaded spindle has safety concerns when working in reverse. Keyed and cam-lock spindles are somewhat more versatile.
An alternative to rotary phase converters and digital phase converters is to re-motor with a DC motor and controller.
Happy hunting!
Thanks, to everyone.
Budget is a significant factor.
I only have single phase available. I checked on cost to bring in 3 phase and it was not going to happen. I’m aware of the phase converters and the delta and Y configurations for 3 phase but have never done any wiring with them. Plenty of single phase and signal wiring.
As for adult ed classes – there aren’t any, i’ve already checked into them. The one course in welding specifically stated that it was for degree students only and not continuing education. (I know there’s a way around that, but being over 70 I’d have a hard time convincing anyone I was changing careers.)
Just so you have some background, I have a full woodworking shop and make cabinets & furniture from time to time now that I’m retired.
I expect to see the machinist tomorrow and see what he says about letting me shadow him at his shop. With the holidays coming up, I really don’t expect anything to happen until early next year.
I appreciate all the information.
/ Machining metal parts #26
The era of Covid has changed much…
Traditionally, community college is open to everyone…
I have used a simple idler 3 phase motor to run my 1hp J head Bridgeport.
Never did anymore than give it a twist of the wrist with one hand and plug in the cord with the other.
This setup has worked with zero issues since the mid 1980’s and took about 10 minutes to set up…
/ Machining metal parts #27
Yup. 3ph motors will run on single phase....just got to get them started. Once running, voltage is "induced" into the third leg....thus you can now run a mill.
ITs not perfect.....Maybe 240v on the two legs you are feeding and 180v on the generated leg. Dont matter, it just needs something to be able to "start" your mill or lathe.
Purpose built converters do some things to better balance voltage. Like more windings on the 3rd leg and capacitors. They also use capacitors to start so you dont have to give it a twist of the hand..
To anyone wanting machining equipment and their holdup is 3PH power......Id say dont let that stop you. Between a RPC, Static, build your own, VFD, etc etc.....you can have three phase power pretty affordable to run a mill or lathe
There is a term for 3ph motors that are "inverter rated". What does that mean? If I'm understanding 3ph motors correctly, they all will work off an inverter. The only concern that I see is that the inverter changes frequency to control the motor speed and cooling could be an issue at lower speeds.
/ Machining metal parts #29
You got it.
They all don't work off am inverter. I fact I'd say most don't in an average industrial setting.
Motors are designed to work at their nominal rpm at 60hz. With a freq drive you can vary this but not much if you want longevity.
Try to run a non inverter motor at load at 5 or 10hz it will burn up shortly.
Inverter motors take extra steps to ensure cooling. Fan design, cooling fins, heavier windings and insulation, etc
/ Machining metal parts #30
Avoid the round column mill-drill like the plague. Been there, much frustration, no T shirt. Now have a Grizz square column bench top unit, big enough for most needs.
/ Machining metal parts #31
Round columns are fine if you you respect their limitations and properly plan your operations. Resetting column Z or heavy x cuts are the main issue.
/ Machining metal parts #32
Where the round column mill-drills really fall down is if you are using end mills and drill bits interchangeably for different operations. The drill chuck sticks out a lot more than a collet and so there is almost no way to position the head at a height where you can do both without having to raise or lower the head due to the limit of quill travel. And for small home machine shop work, that is how you are going to operate. That is where either a square column or a knee mill saves you a ton of time and grief. I had a Rong-Fu round column for a few years and hated it for that main reason. Plus it wasn't solid enough to take any cut at all without chatter. But it was better than nothing. Now I have a Bridgeport that I refurbed this past summer and it is soooo much nicer to use it is like night and day.
/ Machining metal parts #33
When a part requires a change between milling and drilling, you can change r8 collet to the correct size for the drill bit.
/ Machining metal parts #34
Round column machines are fine, within their limitation - you loose the position relative to the table if you raise or lower the head. There are tricks for this, but fussy. Round column mills are great if you need to mill or drill the end of something lone, as it can be clamped off the edge of the table, and the head swung around.
That said, I had one of each, and preferred the dovetail column mill for many reasons. You just need to understand how you'll use the mill, and which limitations may affect what you want to do with it.
If you choose a round column mill, one of these will be your friend:
/ Machining metal parts #36
You can do the same with a knee mill. There is a T slot across the front of the bed. I will say, about the only time I use it is when I am milling the slot for the extractor after I weld the lug to contender barrels.
/ Machining metal parts #37
The first shop I worked in had a repeat job that required drilling and tapping holes on the ends of 4 and 5 foot long stainless shafts. My boss had a concrete coring company cut a 5 inch diameter hole in the shop floor. We clamped the shafts in a fixture that held the shafts off of the front of the table. The ram was rotated and extended so the holes could be drilled and tapped. The shafts were lowered into the hole cut in the floor so that the end work could be done. As a learning project I came in one night and made a cover that resembled a manho!e cover for the hole because stuff kept falling in.
Eric.
/ Machining metal parts #38
Collets are fairly limited in number of sizes and not many drill bits are going to successfully fit in them, but when you can, sure it can help. And most people who own a round column mill/drill are not going to have a collet set in 1/64's increments either... 1/8,1/4, 3/8, 1/2...are what you will probably have.
/ Machining metal parts #39
You can use an ER collet holder with an R8 shank, will give you a wider range with fewer collets then using R8 collets.
Sent from my SM-G715U1 using TractorByNet mobile app
/ Machining metal parts #40
Now you are gonna go an confuse new people.
There are literally dozens of different tool holder types.
R8 with drawbar seems the most common on the Bridgeport type Mills that a home hobbiest would be interested in.
Mine has quick switch tooling with er style collets.
Just going to an ER tool holder instead of directly in the r8 collet may be enough length that you can swap from Mill tooling back to a drill chuck without having to constantly raise and lower the table
INGERSOLL RAND G25 GENERATOR (A60736)
INGERSOLL RAND G25...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2012 VANTAGE TRAILER PMEUMATIC CEMENT TRANSPORT TRAILER (A60736)
2012 VANTAGE...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A59823)
2021 SANY SY265C...
