Machining metal parts
   / Machining metal parts #1
3Ts
Elite Member
East Texas
Case, Kubota, John Deere
In the Drill Press Cross-Feed Table there were some posts where I learned some things to look for in tools. I'm interested in doing some machining as in making some of my own parts, especially if I can't find a replacement, but have never done any machining. There is one machinist in town that I can ask questions of, but he has a business to run and I don't want to interfere with his paying job. So since y'all have been helping one another on this forum I'm going to ask some questions about machining. Keep in mind that my knowledge of this is that I can stick 2 pieces of metal together with a welder and drill holes with a drill press. I also know that there are different alloys of steel, some are not machinable, some can be hardened after machining. Beyond that - not much. So:
Let me start by asking what I should look for in a mill. Ummm, no. First question is what is a mill used for? I think it can be used for cutting slots and keyways, trimming edges once a piece is cut to approximate size, and with a ??? (a circle thingy with a crank) can make circular parts. I believe it would be the first tool in a machine shop and that it should have an R8 chuck. I realize this is a wide open question and I really don't know where to start so comments and guidance is appreciated.
   / Machining metal parts #2
I'm not a machinist by any stretch of the imagination,
I do have my Bridgeport mill it is a small low power one it has a 1 hp 120 volt single phase motor on it.
I have a few milling cutters for it and have managed to make a few pieces and clean up some parts to be reused.
Surfaced a couple of exhaust manifolds so they would seal better, just minor things.
My most common use is as a drill it works so much nicer then any drill press I have ever had.
Plus I picked this up for $500 with several collets and bits and a drill chuck.
Then I have a small very old lathe, it is a South Bend C9-10JR I picked this up for $100 a few decades ago,
I turn a few shafts down and made bushings to weld on them to bring them back to size, made a few little pieces and parts.
Some bronze bushing to fit backhoe pins and tighten up the slop in worn pins and holes.
Even made a puller for pulling engine sleeves on a Allis Chalmers WD45.
The last few years U-tube has been a helper on doing things before that I used old manuals and military training guides.
   / Machining metal parts #3
Have a small shop set up with Southbend 10" Lathe and Bridgeport NC Mill, rotary table, 12" disk sander, Belt Sander, a couple of welders, etc
All used in restoring cars and for a time a small side business fabricating Monel and 316 shafts for antiques.
Mill is great... Lathe could be larger...
Sadly not much use the last 20 years but handy none the less.
When I bought in the 80's prices were high but as manufacturing left the SF Bay Area machine tools plentiful and even cheap... sometimes scrap cheap.
One thing is many are three phase which means a convertor or swapping motors.
Lots of three phase is heavy duty but many home shops pass.
   / Machining metal parts #4
For starters, a mill is often used to make bar stock into mostly square shapes.
The real beauty of a good milling machine is that you can make accurate square or (whatever) blocks and then accurately drill holes and ream them to very accurate sizes. Holes can be accurately spaced apart, from an edge, or from the center of your work. This enables one to take multiple parts, bolt or dowel them together to make a machine or ????
You are correct, with other equipment, you can make round parts or various hole patterns.
I loved running a lathe (mostly to make round parts). it is the only machine that can duplicate itself. It's history goes back to the British Navy needing bolts and nuts. It's off topic but imagine those craftsmen who sat at a vise every day making bolts and matching nuts with a file for their entire lives.
R8 might be the most common but other sizes work just as well. Once you have that determined, then you want to buy collets, drill chucks and other items that will fit. For that reason, R8 is a good choice because it is easy to find accessories for it. Good luck.
   / Machining metal parts #5
I had a nice 20 book encyclopedia set of books all about machining, they would answer your questions! I am a machinist. If you could make your questions a bit more specific, they'd be easier to answer. But, we're here to help in any case...
A milling machine will turn a cutter (expensive to break off) which will cut a flat surface or slot, or locate a number of holes with fair precision. Endlessly useful tool, though you can spend as much on accessories (a vice, rotary table, clamp kit, dividing head, boring head, collets, mills, etc.) as the mill costs. and you'll need some measuring tools to know where you're cutting.
A lather turns things so you can make them round, or drill concentric holes down the middle. Also very useful for cutting male threads, but skill required for that.
Yes, there is all kinds of steel. The most handy thing to save you wrecking an expensive end mill, is a cheap file. If you can't file it, you can't mill it.
Chucks hold drills, usually 1" diameter and smaller. Larger drills have a morse taper shank (there are exceptions, but this is common). Collets hold end mills, and certain size drills. Collets are much more precise, and long term precise than chucks.
I hope that's a small start for you. Youtube is your friend....
   / Machining metal parts #6
I have a Monarch 16x54 lathe and a Bridgeport 2hp knee mill that was formerly a CNC mill (nice ball screws on everything).
Pretty much good advise so far on what a mill can do. Not much to add.
If you are considering shopping/purchasing one.....you need more knowledge/education than can be done on an internet forum. I'd go to the machine shop you have in town....even offer to pay a few $$$ but shadow whoever is running the mill for the day and ask questions. There are lots of Do's and Donts that pertain to safety. And hands on and seeing someone do those things in person....and explain to you why would do way better than me telling you on a forum.
   / Machining metal parts #7
Welcome to the very heavy hobby of machining where one day your wife will look at all of the crap you have accumulated and hopes that she dies first and does not have to deal with it. I got back into it about 20 years ago and now make a living with it after abandoning the IT industry for another one with almost as much tech but weighs much more.
Youtube is your friend, search for something you want to do and there are probably 50 videos of instructions. Subscribe to their channels and you will constantly be presented with new videos. Join the Home Shop Machinist web forum and subscribe to their magazine. Resist the urge to buy chinese equipment - most of it is junk with very hard to replace parts. Have a good pickup that you are not afraid to abuse. Keep some cash rat holed at home because screaming good deals always come along when the banks are closed for a three day weekend. And always remember to have fun.
   / Machining metal parts #8
Depends what you want to do, if you want to have an awful finish, tiny cuts and greatly increase your chance of breaking your drill press you could use one as a mill.
A mill has many uses but might as well be a rock if you don’t have tooling and some are not much more than a drill press with a stronger method of holding the tooling that a taper mounted Chuck.
Personally I would be on the lookout for a used but not beat up Bridgeport series 1 or clone. Buying used equipment often comes with extras that can turn out to be more valuable than just a machine.
As you noted a rotary table or index can add versatility but the last one I bought also came with things like DRO, rotary 3 ph converter, power feed, collets, end mills, drills, 5c collet fixtures and collets, that if bought on their own, would have cost more than just the mill.
That said, often a lathe is the most useful of the two. What kinds of things are you trying to make?
   / Machining metal parts #9
Well said.
Like most hobbies, the machine, tractor, or ATV is just a downpayment on all the stuff that you buy after you thought you had something.
   / Machining metal parts #10
I worked in a machine/model shop part time during my college years -- started cleaning machines at the end of the day and gradually moved up to basic machining tasks on a Bridgeport and lathe. Got lucky that one of the model makers saw something in me and took me under his wing. By the end I could make almost anything and it was a wonderful feeling.
So many times over the years I wished I had my own machines because they give you a high level of independence and capability to fabricate and repair stuff. I still use machines at work occasionally when we get into a pinch, but have never been able to find the space/need to have my own machines at home. I figure it will be a good retirement project someday.
I'd say if you have any inclination, go for it. It's a great way to start as a hobby that turns into a valuable life skill.
One of the coolest things I remember was all the different materials we worked with. I'd say most of the work I did was with aluminum, which cuts very nicely. But in a model shop we worked with everything, including plastics and composites. I machined some real nice parts out of urethane and delrin. Delrin is a great material for all sorts of uses and machines beautifully on a Bridgeport and lathe.
Definitely be prepared for the cost of materials and tooling. Whenever I have looked at used machinery, I tend to focus on the machinery cost, but procuring material and keeping up with tooling, cutters, and supplies can be very expensive. You'll also need maintenance supplies, lubricants, way oil, etc.
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52128)
2022 Gravely...
IH Cub Lo-Boy 154 (A50514)
IH Cub Lo-Boy 154...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
