XU6168 w/ LL5106 loader bucket upgrade
/ XU6168 w/ LL5106 loader bucket upgrade #1
diggitydug
LS UX6168
Hi All -
New to the forum. I have an XU6168 that I'm using for general property work and light forest management. it's looking like most of the tractors value will be in managing timber/slash, cutting roads, grading, gravel. To that end, I'm considering a new larger capacity toothed bucket. Dealer said it's a standard skid-steer quick-connection so the options are near unlimited.
Spec sheet for the LL5106 says it has a 3K lifting capacity, which means it could handle a bucket capacity of around a yard. Anyone tried a larger capacity bucket with an LL5106?
Thanks,
/ XU6168 w/ LL5106 loader bucket upgrade #2
I'd say play with what you got & check your comfort level/lifting needs before investing in a bigger bucket. I'm guessing the extra weight of the bucket will pretty much offset any extra volume capacity unless your simply moving sawdust/twigs & lots of air. I've got the xr4150 w/LL4104 & it's stated lift capacity for the loader is supposed to be ~2700 lb, but I find it tends to be weaker. I couldn't lift a Cummins 6CTA out of trailer (~2k weight) with bucket/chains or pallet forks, but the lift is better closer to grade level. LS has a rep for weak loaders that is related to the pumps they use (at least on the 4XXX & lower series). A grapple might make more sense if it's for the timber, not much help on the gravel. I wound up picking up a mini ex for the lifting/light dozing that the LS wouldn't do & don't regret the decision for a minute.
/ XU6168 w/ LL5106 loader bucket upgrade #3
This is Bobcat's one cubic yard 6' wide bucket for the Versahandler:
Part number 7140706:
With teeth it weighs 818 pounds:
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2019 KENWORTH T680...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
20800 (A56859)
20800 (A56859)
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
