High flow coupler size?
/ High flow coupler size? #1
Cord
Richfield, Wi
Resident Architect
I'm adding a high flow circuit to my skid steer and I want to match industry standard couplers. I don't know if this would be 1/2" or if I should be stepping up to 3/4"? For some reason I suspect many machines are using 1/2" couplers on their high flow circuits.
/ High flow coupler size? #2
What's the flow and size of your lines?
/ High flow coupler size? #3
I have never seen anything other than 1/2" on any skid loader or attachment.
I am sure it may choke a high flow down a tad.....but being able to swap attachments would be troublesome with different size couplers.
IF its all your attachments and you have something that needs as much flow as you can give it.....look at the couplers specs from whatever MFG you choose....size accordingly. ANd if that happens to be bigger than the standard 1/2".....you can make some adapters if you ever rented a something and needed the smaller couplers.
/ High flow coupler size? #4
1/2" Flat Face couplers are considered to be standard flow. 3/4" couplers are generally used in "high flow" applications. There are a range of coupler sizes just like most styles.
I've already looked up the gpm vs recommended coupler size for the pressure drop and know what size is recommended. However, I deliberately omitted this information so as to not sway the responses. What I wanted to know is what the industry standards are.
/ High flow coupler size? #6
Skid steers and CTL's with the high flow option typically have a pair of couplers for standard flow and a pair for high flow applications as well as a case drain connection. The couplers pairs are manifolded to a single pair of supply tubes.
/ High flow coupler size? #7
I would size it based on your flow needs - likely 3/4.
You can make an adapter for your older attachments if you have a lot of them, or simply change them over.
/ High flow coupler size? #8
What attachment are you upgrading the machine for? A gehl 6635 would not be a great choice for a mulcher head, cold planer on the other hand.
1/2” for sf and 3/4” for hf
Looking to change my Alaskan mill to hydraulic.
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
2000 Kenworth Tri-Axle Dump Truck (A61568)
2000 Kenworth...
2021 CATERPILLAR CB1.8 DOUBLE DRUM ROLLER (A62129)
2021 CATERPILLAR...
2014 Kubota RTV X900 4x4 Diesel Utility Cart (A61567)
2014 Kubota RTV...
New/Unused Landhonor Quick Attach Pallet Forks (A61166)
New/Unused...
2008 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2008 JLG 600S...
