Tire valve stem question
/ Tire valve stem question #1
Franko
Schuylkill County, PA
Kubota B7800/RTV900
My Kubota RTV front tire has a valve stem that seems screwed in too far, or something. I have trouble adding air - the little valve plunger in the valve is just too deep. So I bought another valve and tool. So, can I just remove the old one and quickly screw in the new one without jacking the RTV? How hard would it be to do this with the escaping air?
I have not done much with tires and nothing with valves, but I want to make this easy if it makes sense. I appreciate any advice.
Thanks,
Frank
/ Tire valve stem question #2
Yeah...... you will lose all the air even if you jack it. You have no jack???
/ Tire valve stem question #3
Valve stem extenders?
Just lazy. So Jack it up to make sure the tire bead seal stays tight when I lose the air, and then replace it? Sorry for such dumb questions, but thanks much for the quick answer. I have been putting this off and need to get it done before Winter suddenly shows up here.
I see the extender picture. Not sure if the extender would push in the valve enough, if my fill head doesn't. It might. But I don't like the idea of another place to leak. I am thinking I will replace the valve and see what happens. Might learn something.....
Frank
/ Tire valve stem question #6
You are refering to the valve core. I doubt that replacing it will make a difference. In more than 50 years and hundreds of tires,I don't recall a single time that I experienced what you are talking about (inability to put air in tire),,,,,,,,then about 10 years ago I thought something was wrong with the chuck on my air hose. I replaced the chuck and had the same problem. I have wrestled with the problem ever since. I somewhat solved the problem by keeping stem extensions in/on every truck,tractor,car and atv plus a few in shop near compressor. I haven't figured out whether the problem is with stems or chucks but it's a pita for sure.
Thanks, Jaxs, for your report. When shopping I did see different varieties of cores, some longer, some shorter, so I bought I longer one. Not sure what is in there, but I am going to find out. I do appreciate the great help on this site.
/ Tire valve stem question #8
Frank
Extenders work for me. I don't leave them on the stem. I screw the extender on,air tire up then remove extender and return it to where it will be handy next time.
/ Tire valve stem question #9
Thanks,
Frank
Try another chuck for your air hose.
Well, I used my tire gauge and a tire pump chuck, and I was able to read the pressure and add air if I pressed down. Not ideal, but the air pressure was good after a year. So I am thinking I should put off monkeying with this since it is working and we all know how easy it is to create your own trouble.
But thanks, all for the info.
Frank
/ Tire valve stem question #11
I have an old, very old truck axle under a trailer and I have to turn the core out a turn or two to add or check the air, then turn it back in. Dunno why, just works that way.
/ Tire valve stem question #12
Not sayin I'm glad you have a problem, but I know what you talkin about. Got several chucks and gauges and sometimes it seems nothin will work right.
/ Tire valve stem question #13
Use a file and cut down the brass top of the tire valve stem a bit. ... if it's only one tire. If it's all of your tires, check your air chuck.
PS ...blow out all the filings before you try the air chuck. You don't want debris in the valve seat.
2003 Badger 1085D Wheeled Excavator (A61166)
2003 Badger 1085D...
Toro Timecutter Max (A61166)
Toro Timecutter...
Sweeper attachment (A61567)
Sweeper attachment...
2025 SDLanch SDLE20 Diesel Mini Excavator (A60352)
2025 SDLanch...
2006 HONDA RANCHER ATV (A62130)
2006 HONDA RANCHER...
Electric Golf Cart (A56859)
Electric Golf Cart...
