Cable chains for tractor tires?
/ Cable chains for tractor tires? #1
North to Alaska
Gold Member
Talkeetna, AK
Branson 4520r
Did a little scouting online but found nothing. I have to little clearance for regular chains. My other options are studs and cable chains.
tire sized are
16.9x24
12x16.5
not sure if cable chains would hold up under the stress of a 7,000# tractor anyway.
hoping for any insight
thank you!
/ Cable chains for tractor tires? #2
Where is clearance issue? If on inside of tire, can tire spacing be widened? Some people have added spacers for extra width.
Chains are excellent for snow and ice. You will find a variety of opinions on which chains are best, if you need best, and how much to spend.
Any chain is better than no chains.
/ Cable chains for tractor tires? #3
These are low profile for clearance issues. I have them on my L4060.
/ Cable chains for tractor tires? #4
/ Cable chains for tractor tires? #5
Do you have 2 piece rims on your tractor? If so are they set to the widest setting? I think you should be able to set the wheels wide enough to allow for the chains. No money to make the the tires to set out.
/ Cable chains for tractor tires? #6
I'd think that you'll be very disappointed with the cable style. With the deep lugs only a few inches of each cross cable will be in contact with the ground. This condition exists with regular "ladder" style chains also but the chain, crudely having a 3/4" - 1" "diameter" has at least some contact down in between the lugs where the skinny cable would only contact where it passes over a lug.
Clearance is a little less than 1” between tire and fender.
I believe the rims are set to their widest.
The Aquiline and Tryggs both look promising. I do forget just how expensive chains can be😬.
I did try basic roofing screws last winter and they worked very well for grip…until they eventually pulled out(expected that)
There are studs that have wide threads meant for this I may try. Grip studs is one. Less cost upfront but likely to eventually come out? Less grip than chains.
then there is the problem of getting things shipped to Alaska. Not sure I can get access to those chains.
/ Cable chains for tractor tires? #8
I can sure see the problem. I don't think I've ever seen a tractor with so little clearance between the tire and the fender. It might look cool and streamlined I guess, but is of no practical value and is in fact detrimental to some applications as you are finding out.
/ Cable chains for tractor tires? #9
If you can't find what you need for the rears, I'd still get a set for the fronts if there are no issues there clearance wise.
I have had good success with simple 4 link ladder chains.
In your position, I'd get a set of 2 link ladder chain for the fronts.
/ Cable chains for tractor tires? #10
I'm down in Valdez and my dealer installed 3" spacers on my Kubota for chain clearance. The chains that Citydude posted will work if you can get them. I tried chains for about a week and removed them. It felt like I was driving on an extension ladder. I switched to screw in studs. https://www.koldkutter.com/products-1 Takes time to install and remove in the spring but I have the time to do it. I got stuck two times. Once out at the road but the snow was light and fluffy and I drove off into a pile 5' deep. Same up by the house, my fault. It was a light fluffy snow year last year. Ice was no problem and going up my 10 degree drive was no issue unless I was pushing heavy stuff from the state plow. Not much snow here last year maybe 280" and that was it.
/ Cable chains for tractor tires? #11
You must have been using the regular old style chain, the boxed style, OFA, Aquiline and Tryggs provide a smooth ride as you are always on chain.
The conventional style 2 or 4 link will give you a tough ride
/ Cable chains for tractor tires? #12
I DIY'd a set of 2 link ladder chains for my CUT that had so little clearance that my hand won't fit.
Mine are made with the euro welded stud type ice chain.
The secret is good binders to prevent the cross links from flinging out.
I even DIY'd my own binders using HD bungy cord and 'S' hooks.
/ Cable chains for tractor tires? #13
The answer is simple. It's just not designed for the use of chains.
/ Cable chains for tractor tires? #14
I live in SW Michigan and I use H chains on my tractor(2wd). They cost about $350 about 10 years ago but very strong links. The H keeps them on top of the lugs. Not a noticeable difference in ride. I used to plow my 1/2 mile driveway with a S-10 pickup. I put the chains on the front so I had steering control. Looking at the picture, I’d put the chains on the front.
/ Cable chains for tractor tires? #15
Everytime I swap trucks, I take those "snow chains" out and throw them in the garage. I bet there are probably half a dozen bags with them out there. We don't need them down here, and they aren't legal to run in most states around here.
I have thought about making up a set for my JD2555 just to see if they would help in the mud!
David from jax
/ Cable chains for tractor tires? #16
David from jax
They indeed help in mud.
2002 Vermeer SC252 Walk-Behind Stump Grinder (A61572)
2002 Vermeer SC252...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A61572)
2023 Caterpillar...
2013 VOLVO VNL 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2013 VOLVO VNL 6X4...
2014 GMC Sierra 1500 Crew Cab Pickup Truck (A61573)
2014 GMC Sierra...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
LOOK! (A63116)
LOOK! (A63116)
