Oil & Fuel Yanmar 155D Loader Fluid Capacity
/ Yanmar 155D Loader Fluid Capacity #1
Dowork88
Massey Ferguson 204
I’ve searched and searched. Can anyone please help me out with the fluid capacity for the loader on this thing? I just picked the tractor up for 2k and I’m very happy with it. Going through maintenance now. Any help is appreciated!! Thanks
/ Yanmar 155D Loader Fluid Capacity #2
What brand of loader? We know the hydraulic level for the YM155 without power steering because the FREE manuals tell us on the Yanmar Tractor Owners Group site. :)
/ Yanmar 155D Loader Fluid Capacity #3
Does the tractor have a loader or do you plan to add one? If the tractor has a loader, it uses the same hydraulic fluid as the three point and the transmission. Once the loader has been added and the fluid serviced there is no real change in fluid levels. When you change hydraulic fluid the cylinders are (or are supposed to be) retracted so the only remaining fluid is what's in the lines.
It has the YFL 155 loader on it. Thanks everyone for the info. I can’t believe the price of the manual for the loader on eBay! $100 plus shipping. The seals leak on the upper cylinders so it was low. I decided to drain it and replace it, which brought me to my dilemma. From everything I can see, the FEL has a separate reservoir for fluid and the fill port is on the top right arm assembly near the controls. Thanks everyone!
/ Yanmar 155D Loader Fluid Capacity #5
Double check that before doing anything. If your loader has a separate reservoir then the setup may not be original. I thought all the YFL series loaders were plumbed in series before the 3-point lift, so the fluid came from the transmission sump.
Sump > pump > loader control (passing straight through when the loader isn't in use) > 3-point.
The next larger size Yanmars take around 4 gallons of UTF to fill the transmission sump. Yours might be 3.5?
That was my estimate based on the Koyker which was similar. I just drained it out of the bottom of the loader assembly. It’s set up a lot like my Massey industrial. I’ll try and attach a picture. Thank you!
/ Yanmar 155D Loader Fluid Capacity #8
Interesting! That's the exact same AICO loader control that was presumably dealer-installed along with my Great Bend (third party) loader on my YM240, before it was sold new in 1980. And I've seen that control widely used back in the day on 8N loader installs.
But your loader structure is completely different from the Great Bend loader, or the Yanmar loader on my YM186D.
What feeds the input side of that AICO loader control?
Looking at that again - is that a low pressure reservoir before the fluid returns to the sump, or an isolated system driven by a second pump, or ???
/ Yanmar 155D Loader Fluid Capacity #9
All I have on a YFL155 is the sales brochure. I think rScotty first posted it on the site prior.
Thanks for that! I honestly have no idea. I know there’s a pump behind the front bumper which I believe powers the fel. I added fluid where you can see the white cap on the top, but it started spewing back out when operated. I think it might be all controlled by the fluid in the transmission. I’m also fairly certain these are self bleeding systems, so I may have overfilled it. Drained some of what I added and it seems better now. The entire manual is way too expensive.
/ Yanmar 155D Loader Fluid Capacity #11
... have no idea. I know there’s a pump behind the front bumper...
And I see 'Independent Hydraulic System, 800 PSI', in the rScotty / bmaverick brochure.
So that system is independent of the transmission sump and the 3-point hydraulics. Interesting.
I don't think you are missing anything without the manual. The AICO valve, and I think all the rest of it, are generic USA components so any local hydraulic shop will have hoses, seals etc to maintain it. Not a problem.
My AICO control dribbled badly - on my shoe - under load so I replaced it. There's an old thread on here somewhere about the conversion to a Prince valve with the hoses exiting beneath. But I doubt yours is worn out.
Thank you! I see you’re in Sonoma County… I’m just a little north of you in Butte County.
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
More info coming soon (A61574)
More info coming...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
ATTENTION PLEASE READ (A64126)
ATTENTION PLEASE...
