Pat's quick hitch set screw/bolt design issue??
   / Pat's quick hitch set screw/bolt design issue?? #1
disney
Gold Member
orlando fl
scag turf tiger 61" #2, gx95, sold f525 twice, f725 sold
Greetings all. I picked up a used Pats quick hitch for not much because the pervious owner sheared one the set screw/ adjuster bolts when he was trying to remove it. It was an easy fix for me to remove it, but I have found what I think might be a design issue, or at least poor planning. It appears that the ends of the all adjuster bolts (eight in total 3/8" GRADE 2--so SOFT METAL) have mushroomed from contacting/holding against the lift arms. If anyone were to try to remove the bolts, as soon as the damaged/mushroom section hits the cast section of the Pats, the soft grade 2 bolts will just shear off. I would think either grade 5 or maybe not having threads on the end of the bolts would be a much better idea, and would only have raised the total cost of a Pats set at most a dollar. I know people may not often remove the pat's but I do not think that is a good excuse for this. I am over looking something, or ???
I did not think to take pictures of the inside, but you can see the sheared bolt from the outside.
   / Pat's quick hitch set screw/bolt design issue?? #2
I removed all those soft bolts from my Pat's hitch. I replaced them with appropriate Allen screws. I used different lengths based on where I put them and how I wanted it adjusted. The Allen screws will allow me to remove them by screwing through.
   / Pat's quick hitch set screw/bolt design issue?? #3
Great idea!
1993 Harsh Feed Mixer (A51039)
1993 Harsh Feed...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2015 MACK GU 713 (A50854)
2015 MACK GU 713...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
