Snow boots
/ Snow boots #1
nfisheremti
Kubota L3800 HST
i need new boots. i do snow removal in an open station Kubota L3800. i spend about 2 hours a day when it snows clearing neighborhood driveways. i have a pretty decent snow suit, balaclava, heated gloves, etc. but my 30 year old sorels aren't cutting it anymore. my toes are solid chunks of ice by the time i get back to the house. temps can be anywhere from around 32F to -20F. i'm doing this before my real job, so it's 4am or so, often snowing hard. i spend very little time out of the seat moving around, but i am working the pedals pretty hard with both feet.
what do you guys use? any recommendations? my primary goal is warm, followed by easy on/off, good traction on snow and ice, durable, and finally price (i don't mind paying if they're going to last).
thanks,
n
/ Snow boots #2
I have the same classic Sorels with felt liners for decades. They are big and bulky but are in xlnt shape, warm, and decent traction. Don't know if they still make them like they used to.
/ Snow boots
That's that I have now. I've been reading reviews and from all I can tell, they don't make 'em like they used to.
I'm looking at Baffin Selkirks. Anyone have experience with them?
/ Snow boots #4
800g Cabela's work boots. I'm on my fourth or fifth pair. On sale they're around $89.
Edit: they don't offer them anymore. I've been buying them since 2005.
Have you ever considered something like this? https://www.westonstore.com/products/heated-socks?variant=37412449353918&utm_medium=cpc&utm_source=bing&utm_campaign=Bing Shopping&msclkid=df2e7d1091ab162778a71c680ee786b0
I'm not generally a fan of electric clothes, it wouldn't be good if they suddenly crapped out when I'm a mile from the truck. In your case though they may be just what you need.
/ Snow boots
I have some heated gloves the wife bought for me a few years back. They last about 4 hours. But the batteries are a bit clunky.
I have Reynaud's syndrome, so my fingers and toes are always suffering. Maybe electric is the way to go
/ Snow boots #7
SNIP
thanks,
n
We get real winter here, too. I used to use heavy winter boots, although as I've aged I think what works best for each person is very individual.
Anyway, my feet were getting cold, so I switched from boots (Sorels with fur liners & RedWings with double wool socks) to a different thing entirely.
This is going to sound crazy but it works for me. Now I use an overboot like the NEOS (google them). Inside each NEO overshoe is a favorite comfortable old and rather large low top tennis shoe that stays there permanently. When I want to go outside, I simply slide my stocking feet into that rig, slap the front to engage the hook and loop, and I'm good to go all morning.
Although if the snow is deep I also roll up and fasten the built-in snow gaiters .
Since the price is so reasonable I have two sets. As the snow deepens and slippery ice forms outside I add aggressive chain Yak Traks to one pair. The Yak Tracks then stay on that pair for the remainder of the winter.
The key to the whole thing is that the NEOS need to fit loose enough and the Yak Traks need to fit tight enough.
YMMV
rScotty
/ Snow boots #8
When plowing with my previous open station tractor I used heated gear by Gerbing. I wired a 12v plug near the seat. Overkill for most outdoor work, but for sitting on the tractor for several hours it was perfect.
I have heated socks, pants, vest, and gloves.
As far as current snow footwear, I like Haix boots. I wore them as my work boot for years as a firefighter. Lightweight and comfortable like sneakers, totally waterproof and breathable.
/ Snow boots #9
I keep telling you fellow "open station" guys about heated motorcycle gear. Snowmobiling, (depending on your riding) is a physical activity, at least a lot more physical than driving your tractor. Your extremities, especially as you age will naturally get cold so that gear/clothing is not the answer. About 8 years ago I visited a "touring" type m/c accessory store, told the owner my story and he suggested that I "build" my winter plowing suit starting with a heated jacket. He told me that he found that keeping your "core" warm was the best 1st step and if needed, pants, socks and gloves can be added.
He was 100% correct, I walked in there expecting to buy a total "suit". He made sense and saved me money as I've not added any of these pants, socks etc. I think I spent about $300 for the wiring to tie into a vehicle's 12v and a controller and this includes the jacket.
I couldn't be happier and I go out plowing for about 5-6 hours on my little 25 or so driveway "route" about 20 times a winter. 👍
/ Snow boots #10
Over the years I found snowmobile outfit works the best (y) ...boots 1 piece suit and gloves...some time suit can be to warm.
/ Snow boots #11
There are lots of good winter boots out there. Many people forget about socks. All socks are not equal. Get a good quality pair, or two, of polypropylene socks. They will wick moisture away from your feet. Then wear a good set of wool socks to put over them. It'll help tremendously if not doing so already.
/ Snow boots #12
Poly socks feel like your foot is in a garbage bag.
For hunting (minimal movement cold weather, 10*f) I use wool lined Sorrel boots with cotton socks, toe warmers over the sock then a thick wool sock over that. If/when I get cold I turn on my Milwaukee heated vest that's just over my 30% wool base layer.
What are you useing for other clothes? Usualy hands and feet getting cold means your body isnt warm enough.
/ Snow boots
i typically use a set of fleece thermals, under an occumex hi-vis snowsuit. wool socks, and my old dead sorels (which i want to replace). up top, i have a fleece balaclava, hi-vis hood. hands i have a set of heated gloves the wife bought me last year. the gloves are supposed to be touch screen compatible but they're not, which means i'm always popping my left glove off (i'm a lefty) to record my times at each job. i've had to repair the left glove several times because it doesn't like being pulled off 20 times a day. i can usually remember several jobs, so 20 is probably an exaggeration, 15 is probably more like it. either way, the left is flakey a lot of the time. as mentioned before, i have Reynaud's. as i'm sitting in my office (temp 68F), my toes are killing me. even though i'm well dressed, jeans, socks, hoody, and a beanie. Reynaud's sucks (it's not circulatory, it's a nerve thing - but it makes my extremities very sensitive to cold).
/ Snow boots #14
Does your butt get cold? For me cold butt and neck means I'm cold. I bring a cushion to sit on also.
O and my Sorrels are about 3yrs old. I tried columbia bugga boots. Absolutely terrible boot. Even with double wool socks and toe warmers my feet froze in those things. Sorrels kept me nice and warm.
/ Snow boots
Sometimes my butt gets cold, but it's usually when i forgot to flip my seat up before it snowed. my suit is a few years old, and i need to spray it again. my sorels are something like 35 years old, they aren't cutting it. i was looking at them the other day, and the rubber at the toe is all split.
/ Snow boots #16
I have a "hot pad" for the tractor seat. Normal snow - normal temps - Mucks. If it's really cold - I stay inside OR it's my Canadian Sorels.
With the Sorels ( Glacier XT ) I will wear Polar Teck socks under wool socks. It has to be REALLY cold and I have to be out there for a very good reason. This will usually mean Eddie Bauer down pants and down parka. With down gloves.
/ Snow boots #18
Unless its really cold, i dont even wear socks!
Me neither. I've never found a pair that stayed up well in boots, they always seem to work their way down and bunch up under my feet.
My current boots are warm enough I don't really need socks. Just went out and looked, they're Kamik. Don't remember where I got them, says they're made in Canada. A bit heavy, but warm.
/ Snow boots #19
I have a vintage pair of Red Ball Polar Extreme boots. I don't think they even make them anymore.
/ Snow boots #20
thanks,
n
2nd the recommendation on Sorrels. I also have had a pair for probably 25 years. I replace the liners every few years as they get crushed over time on the bottom. I do notice my feet get colder as I get older, probably circulation issues.
Tim
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2022 KUBOTA KX057-5 EXCAVATOR (A65053)
2022 KUBOTA...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59914)
2020 KENWORTH T680...
2025 Intersate Fabrique 12' x 6' Dump Trailer (A62613)
2025 Intersate...
2019 MAGNUS TRAILER MOUNTED HYDROVAC (A65643)
2019 MAGNUS...
