Backhoe Stand
/ Backhoe Stand #1
JTMachineDesign
Joshua Tree, California
LS MT125 TLB
I've got an MT1.25 with the backhoe. When it's removed I have it sitting on some big wood blocks but that gotten old now, Thinking about welding up a platform/stand/throne for the backhoe to relax on while it's off the tractor. Anyone else do that? Got pics?
thanks!
Bill in Joshua Tree, CA.
/ Backhoe Stand #2
If you search for “backhoe dolly”, I think you’ll find what you are looking for. There are a handful of YouTube videos showing how people built theirs. Some are welded, some are built from wood. Most are on caster wheels so they can be rolled around on a garage floor when not attached.
/ Backhoe Stand #3
My BH weighs 1,200 lbs. When I disconnect it (in the last garage bay) I just release the pressure and let it sit on the concrete floor.
/ Backhoe Stand
yup, tried that.. no joy. Besides, I'm not looking for a "dolly" Just something to perch it on when I'm not using it. I have no desire to roll it around on a platform :)
/ Backhoe Stand #5
If you’re gonna just keep it stationary, just throw a 4’ square plywood underneath and call it a day. It shouldn’t be complicated.
/ Backhoe Stand
Where I live, plywood on the ground is prime mouse/rat housing, and therefore, snake magnets
So you see, it CAN get complicated :)
/ Backhoe Stand #9
My BX backhoe is only around 700 pounds. For winter, I put the bucket and the part that mounts on the tractor each on one of these dollys. It works well, except, trying to go over some of the larger cracks, in my garage. My garage was originally a one car, but was expanded to a two-car, many years before I bought it.
/ Backhoe Stand #10
The Kubota B26 backhoe manual says to block under when disconnecting but not how much. It was a real pain to connect to if on the ground. Simply used some timber screws and four pieces of 4x4”, 4x6” short lumber scraps to make box frame pallet. 8” off the ground. Being screwed together the Blocks don’t slide or roll when disconnecting or connecting and supports are in the right place. Now R&R is easy, quick and safe.
The larger M59 backhoe has no problem being stored on the ground.
/ Backhoe Stand #11
/ Backhoe Stand #12
that just made my day!
screwed up again!
i have the same BH and have nitemares about removing it
sone i must!
Follow the instructions and it’s easy. Before I disconnect the hydraulic line I raise and chain the stabilizers to each other, takes up less room in the garage. Putting the 3PH takes the longest.
/ Backhoe Stand #13
Have owned several backhoes. Never seen where storing with the outriggers raised for storing was a option from the manufacturer. Understand floor space issues but it makes for a more unbalanced attachment unsafe.
Good experience shared showing how quick things can go wrong. I too have made my share oops to learn from.
/ Backhoe Stand #14
BH storage question.
my stabilizer arms leak down slowly. i'm told this is common. i cobbled up a strap to keep them in the full up position but....
if the arms leak, what good would it do to use them during storage?
i see at the dealer and most videos the arms are on down, feet on the ground.
just curious
/ Backhoe Stand
Agreed. I store mine with the stabilizers down. But, I don't store inside because I simply don't have room for it and stuff tolerates being outside in the desert :) I park stuff under a roof just to keep the sun off, that's about it.
The biggest issue here is rodents. We have over 40 species of rodents from mice and rats to squirrels, bats, you name it. Some will chew on wires IF they're in secure places but the biggest problem is they attract snakes. So, no tarps (which create ideal hiding places) and nothing laying on the ground. (had a neighbor use a platform of old pallets for firewood.. massive gathering of undesirable critters) I've been setting the backhoe on some 6X6 blocks but I've found rat holes under those so now I'm thinking a welded steel tripod made up of some 1X2 rectangular tubing (with the ends sealed).
Oh! also realized that rodents dont like to hang out where there's a lot of light so, strings of solar-powered LED lights at ground level has been VERY effective rat deterrant, I have them under my vehicles and trailers too.
I spent the first 66 years of my life living in high density coastal California tract homes - moved to the high desert to get more space, fewer people (especially fewer ragin democraps) and peaceful surroundings... got all of that in spades. What I didnt realize was the incredible abundance of wild life... tarantulas, snakes, lizards, bats, lynx, coyotes, big horn sheep... love them all (hate the scorpions though - stung twice). add a couple of dogs and some feral cats and it's pretty darn safe.
/ Backhoe Stand #16
just curious
Just basic safety practices. When storing the Lower center of gravity. Also if tipped will not go down fast.
/ Backhoe Stand #17
I have a BH77. I just block up while the hydraulics are still attached . Rests comfortably on the blocks
When I put it back on the tractor, just back up, hook the hydraulic lines, lift and remove blocks
/ Backhoe Stand #18
I built a very simple and ugly dolly the right height to remove and install my backhoe. Having wheels to move it around makes installing and removing much simpler not mention storage.
The backhoe is ‘sunk’ into the dolly and cannot fall off and I don’t think I could tip it if I tried.
I was going to clean it up and paint it but… meh.
/ Backhoe Stand #19
I think a your dolly is very cool! Well designed for your equipment to safely store. Not everyone has your skills.
/ Backhoe Stand #20
I've done 3 different things with mine since owning it. Like some on here, mine is a 3 point BH, and originally I used to store it in a closed box truck when not in use. I built a 4' square platform with casters on it and set the BH on the platform, then set it in the truck with the FEL. That got old after a while and the FEL seemed to be getting tired of picking that thing up. My next venture was to use 4 2 X 4 square tube with a 3/8" thick plate, (for a foot I guess,) that someone made and I inherited, and there just happens to be four of them. I welded some more pieces of that same plate to the tops and made some tabs that straddled the frame of the BH. Drilled holes through the tabs and BH framework where not structurally important and stuck high-grade bolts through them. The legs were long enough to hold the BH off the ground at about working level. So all I had to do is raise it a bit above travel or work height, put in the 4 bolts through the legs, set it down on level and ground, and cover it to protect it from the weather. It, like another member mentioned, is extremely stable and I tried to knock it over but can't. FInally, some years later I built a carport and now store my unused implements under it. For the BH I stacked some cement blocks, (about 2 high,) and laid pressure-treated wood on it for a deck. Now I back the BH over it, set it on there, and disconnect. It's ready for a reconnect just by backing up to it. My outriggers also settle when not used so using them for storage is out. They also have lock hooks on them so you can lock them in the up position to prevent sag.
One thing here in Florida where I live is you can't just throw wood down on the ground and store anything on it because of the termites. Even pressure-treated in direct contact with the ground doesn't stand much of a chance. The stack of blocks with termite plates between the blocks and lumber works well though. Makes for easy disconnect and hook up. (Sorry this was so long.)
120in. Fork Extensions (A61567)
120in. Fork...
2001 Freightliner MB55 Bus (A61568)
2001 Freightliner...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
2007 TRAILMOBILE 53X 102 T/A DRY VAN TRAILER (A59909)
2007 TRAILMOBILE...
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
2023 John Deere 6R 145 Tractor (A63109)
2023 John Deere 6R...
