Opinion on previous owner's rationale for welding 3PH lever
   / Opinion on previous owner's rationale for welding 3PH lever #1
Husaberger
CA
L4740 HST, DK65S
Just bought an L4200 DT
Previous owner welded the 3PH lever saying that it will prevent deadheading the pump with the backhoe attached
Does this make sense to anyone?
   / Opinion on previous owner's rationale for welding 3PH lever #2
It makes sense if he rerouted the fluid flow from the 3ph pump. Otherwise, no.
   / Opinion on previous owner's rationale for welding 3PH lever #3
With that 3 pt backhoe setup, the 3 pt can't move up or down. If the 3 pt lever was accidentally moved up, it would force the fluid through the relief valve constantly since the 3 pt can't really go up.
So to prevent that, he welded the 3 pt lever in place, which is honestly quite an extreme measure. He probably had that happen to him, till eventually damaged the pump, most likely from the oil getting crazy hot from being constantly forced through the relief valve.
The 3 pt backhoe has it's own pump running of the PTO, so that has nothing to do with the tractor hydraulic system.
   / Opinion on previous owner's rationale for welding 3PH lever #4
If was patient enough, it wouldn't have taken more than 30 minutes to fix up a removable clamp and set screw to do the same thing.
Thank you everyone for replying
Will be taking weld down
   / Opinion on previous owner's rationale for welding 3PH lever #6
Why would you do that when you got a rod burner sitting there doing nothing? :ROFLMAO: :ROFLMAO:
   / Opinion on previous owner's rationale for welding 3PH lever #9
Could a guy just remove and reassemble the stop onto the other side of the stick? Add star-type lock-washers above and below the quadrant and reef 'er down. btw, if the hoe is never off and the lever wont be moved by new owner, after a few rains or washes the stop might rust in place. [BTDT]
(I'm always trying to think outside the Cheetos bag.)
   / Opinion on previous owner's rationale for welding 3PH lever #10
1992 Ingersoll Rand 185 185CFM Towable Air Compressor (A55973)
1992 Ingersoll...
2021 Fleco DX140 24in Digging Tooth Bucket Excavator Attachment (A55973)
2021 Fleco DX140...
72in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
72in Dual Cylinder...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
