Does anyone know where I can find the spanner for this cap
   / Does anyone know where I can find the spanner for this cap #1
RobertBrown
Elite Member
Florida
Bolens G192/TS1910 Ford/New Holland 1920
Ford New Holland 1920
Power steering cylinder.
   / Does anyone know where I can find the spanner for this cap #4
I suspect that since 1920 the most commonly used method or loosening and tightening was a hammer and drift as Sawyer Rob suggested. An adjustable (or appropriately sized fixed) "C-hook spanner" e.g. Proto #JC472, JC479 or similar may also work, and you can spend as much on quality as your wallet will stand.
   / Does anyone know where I can find the spanner for this cap #5
Yep, the right tool for the job,
Problem is cost can often exceed the repair for a 'one of'.
OK for the pro's that do hydraulic repairs daily.
   / Does anyone know where I can find the spanner for this cap #6
Is this the same steering cylinder you repaired in 2015? If so, probably should consider removing the cylinder assembly from the tractor and taking it to a repair shop that has the proper tools. I just did that with one of my FEL cylinders and it is working fine.
That's exactly what happened. I took it to a hydraulic shop and they rebuilt it. Now it's leaking again.
Was it 6 years ago?
   / Does anyone know where I can find the spanner for this cap #8
A hammer and punch will work or a spanner is pretty easy to fabricate.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
48" Metal Pipe (A53316)
48" Metal Pipe...
Sheets of 12' Tin (A53316)
Sheets of 12' Tin...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A54814)
2012 Freightliner...
2016 Ford F-450 4x4 Ambulance, VIN # 1FDUF4HT3GEC45874 (A54865)
2016 Ford F-450...
CAT CS563 (A47477)
CAT CS563 (A47477)
