Does anyone know where I can find the spanner for this cap
   / Does anyone know where I can find the spanner for this cap #1
RobertBrown
Elite Member
Florida
Bolens G192/TS1910 Ford/New Holland 1920
Ford New Holland 1920
Power steering cylinder.
   / Does anyone know where I can find the spanner for this cap #4
I suspect that since 1920 the most commonly used method or loosening and tightening was a hammer and drift as Sawyer Rob suggested. An adjustable (or appropriately sized fixed) "C-hook spanner" e.g. Proto #JC472, JC479 or similar may also work, and you can spend as much on quality as your wallet will stand.
   / Does anyone know where I can find the spanner for this cap #5
Yep, the right tool for the job,
Problem is cost can often exceed the repair for a 'one of'.
OK for the pro's that do hydraulic repairs daily.
   / Does anyone know where I can find the spanner for this cap #6
Is this the same steering cylinder you repaired in 2015? If so, probably should consider removing the cylinder assembly from the tractor and taking it to a repair shop that has the proper tools. I just did that with one of my FEL cylinders and it is working fine.
That's exactly what happened. I took it to a hydraulic shop and they rebuilt it. Now it's leaking again.
Was it 6 years ago?
   / Does anyone know where I can find the spanner for this cap #8
A hammer and punch will work or a spanner is pretty easy to fabricate.
2013 Ford E350 Box Truck (A47477)
2013 Ford E350 Box...
2016 Kubota SVL 75-2 (A47477)
2016 Kubota SVL...
2017 Jeep Patriot 4x4 SUV (A55758)
2017 Jeep Patriot...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
Giyi Stump Grinder (A53316)
Giyi Stump Grinder...
New/Unused CFG Industrial YSRT14 Min Skid Steer (A54865)
New/Unused CFG...
