Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts
Good parts illustration (y)
that’s the older version pre Tier4 bracket before my 2018 Final tier4 bracket in my pix.
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts #22
Did you find what you are looking for?
Yes I ordered the $713 BXX10085 assy like in my pix to match my 2018 tractor exactly. No hoses included at that price tho :cry:
JD hoses was over $100ea
Would any of You guys need or know of anybody looking for a set a Radial R1 15.5-R38 rear & 13.6-R24 front Ag tread tires & wheels for a 5&6k series JD ?
Six78 98six 322six in N GA.
this 115M I’m buying has these & there way too tall for my application
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts #25
How much do you want for them?
3950
their around 7k for new set of radials
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts #27
Let me check my tire sizes. I really want radials.
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts #28
How many hours on that machine BD?
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts #29
The fronts I think would fit, the backs won't. My backs are 18.4 x 30. I have 12.4 x 24 on the front.
It Just clicked 300hrs.
im thinking the rears are same height as your 18.4-30’s
See the fender clearance.
I’ll know more as soon as I get tractor here on the farm to swap tires & wheels.
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts #32
I like those fronts. The rears probably are the same height but they wouldn't fit my rims.
I’m selling them complete : mounted on the JD rims
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts #34
When you get the tractor home I would like to know the overall height of each. I want to make sure the ratios match my ratios.
Ok. Text my phn # posted with the first pic & I’ll reply late next week when I receive it With heights
got my kit today & pre-assembled it finger tight.
it came with all the needed fittings on tractor & loader including the 3rd function but no hoses
the used 5115M came in last night after dark.
We got it transformed with the R4’s after removing the tall R1 radials & hydraulic couplings installed before bedtime
Also cut 15” out of the upright exhaust pipe. 👍
Now waiting on hydraulic hoses from local hydraulic shop.
Most JD 5k Series Open station tractors don’t come with :
32spd trans
Creeper Gear trans option 16 additional speeds below 1mph
Air seat
Horn
Turn signals
Brk lights
3rd function mid & rear hydraulics
Hammer Strap draw bar Hitch
Radial Tires
It’s loaded up with all available options by the build sheet I have on it.
I Love it
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts #39
Good looking tractor. Keep her clean. :ROFLMAO:
I had hoses made with 90* flat face o ring fittings on upper ends to eliminate the 90* double ended fittings like came from JD on my other tractor.
this is a cleaner less cluttered look imo
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
DEUTZ MARATHON...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
Dexter trailer axles (A61567)
Dexter trailer...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2018 CHEVROLET EXPRESS 3500 4X2 BOX TRUCK (A59906)
2018 CHEVROLET...
