Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts
Good parts illustration (y)
that’s the older version pre Tier4 bracket before my 2018 Final tier4 bracket in my pix.
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts #22
Did you find what you are looking for?
Yes I ordered the $713 BXX10085 assy like in my pix to match my 2018 tractor exactly. No hoses included at that price tho :cry:
JD hoses was over $100ea
Would any of You guys need or know of anybody looking for a set a Radial R1 15.5-R38 rear & 13.6-R24 front Ag tread tires & wheels for a 5&6k series JD ?
Six78 98six 322six in N GA.
this 115M I’m buying has these & there way too tall for my application
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts #25
How much do you want for them?
3950
their around 7k for new set of radials
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts #27
Let me check my tire sizes. I really want radials.
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts #28
How many hours on that machine BD?
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts #29
The fronts I think would fit, the backs won't. My backs are 18.4 x 30. I have 12.4 x 24 on the front.
It Just clicked 300hrs.
im thinking the rears are same height as your 18.4-30’s
See the fender clearance.
I’ll know more as soon as I get tractor here on the farm to swap tires & wheels.
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts #32
I like those fronts. The rears probably are the same height but they wouldn't fit my rims.
I’m selling them complete : mounted on the JD rims
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts #34
When you get the tractor home I would like to know the overall height of each. I want to make sure the ratios match my ratios.
Ok. Text my phn # posted with the first pic & I’ll reply late next week when I receive it With heights
got my kit today & pre-assembled it finger tight.
it came with all the needed fittings on tractor & loader including the 3rd function but no hoses
the used 5115M came in last night after dark.
We got it transformed with the R4’s after removing the tall R1 radials & hydraulic couplings installed before bedtime
Also cut 15” out of the upright exhaust pipe. 👍
Now waiting on hydraulic hoses from local hydraulic shop.
Most JD 5k Series Open station tractors don’t come with :
32spd trans
Creeper Gear trans option 16 additional speeds below 1mph
Air seat
Horn
Turn signals
Brk lights
3rd function mid & rear hydraulics
Hammer Strap draw bar Hitch
Radial Tires
It’s loaded up with all available options by the build sheet I have on it.
I Love it
/ Hydraulic Hoses, Couplers & Brackets for JD 5115M Loader Frame Bracket Mounts #39
Good looking tractor. Keep her clean. :ROFLMAO:
I had hoses made with 90* flat face o ring fittings on upper ends to eliminate the 90* double ended fittings like came from JD on my other tractor.
this is a cleaner less cluttered look imo
2020 CATERPILLAR 304E2 CR EXCAVATOR (A62129)
2020 CATERPILLAR...
1611 (A57192)
1611 (A57192)
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
2019 CM TRAILER CARGO TRAILER (A60736)
2019 CM TRAILER...
Prep Table (A60352)
Prep Table (A60352)
1988 FONTAINE 45' STEP DECK LOADER TRAILER (A60736)
1988 FONTAINE 45'...
