acetylene regulator
/ acetylene regulator #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST,
anyone have a good online source for a small regulator ?
I believe they call it a B tank regulator for the small HVAC type tanks. Not The Large Tanks
/ acetylene regulator #2
You have the terminology correct, that's pretty much the std type of tank. The next smaller tank is the "MC" tank and there are adapters to use either with the B regulator.
We ran Turbo-Torches and from what I have seen it's pretty much the standard these days..
not the reg / kit I'm looking for. It should have gauges. I also use oxygen with this kit to braze HVAC lines
Should like a large tank reg. but smaller
/ acetylene regulator #4
Ok, but that is a standard B regulator so the next step up would be a mini or portable oxy/acet regulator set.
Just about any size acet regulator can be easily adapted to a B tank by replacing the tank spud.
/ acetylene regulator #5
Gauged regulators are pretty "generic" how it connects to tank will be specific to tank size....Check trough link below for proper tank fitting or adapter.. Start at "Industrial Products" tab... Maybe find your way to "Cylinder Adapters" (download PDF file)
PULL TYPE YARD SPRAYER (A64278)
PULL TYPE YARD...
2018 CASE TV380 SKID STEER (A65053)
2018 CASE TV380...
2010 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2010 Ford F-250...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2021 Scag Turf Tiger II 52in Zero Turn Commercial Mower (A64194)
2021 Scag Turf...
