Tractor flip
/ Tractor flip #5
YIKES. The chain-a-log to the rear wheels makes sense to get yourself unstuck, but if you're pulling out another stuck vehicle, well DUH.
That was scary. Especially after he's already down and then gets whacked back towards the truck. Wonder how they got the tractor stopped; hopefully it just stalled immediately as the video ends.
/ Tractor flip #6
He should buy lottery ticket...luckeyyy
/ Tractor flip #7
Thank you for posting...
Showing what can go wrong when things go sideways may prevent repeats...
/ Tractor flip #8
There a reason for long chains / cables. Pull from solid ground, not the bog the stuck vehicle is in.
/ Tractor flip #10
Lucky. At first I thought he was trying the "chain through the wheel" trick... something I did many times in my younger days but would never attempt now.
/ Tractor flip #13
That's why I always back up to pull stuck vehicles/objects, never forward. Eliminate the roll-over issue.
/ Tractor flip #14
When I first got my 9N I tried pulling a log from the woods and the from came up a couple feet. Scared the crap out of me.
Eric
/ Tractor flip #17
Least it was a Dodge pickup truck that took the hit. Worthless anyway. :p
Again you are clueless..Great comment :poop:
/ Tractor flip #19
THIS is precisely why I'm only shopping for a hydrostat tractor. My daughters will be learning to drive it too, and if things get weird, just lift your foot. It's not 100% foolproof, but it helps when neither of them have ever driven anything with a clutch.
/ Tractor flip #20
That makes a lot of sense. I’m on the other end of the spectrum, 3 years after buying a hydro I still find myself using the clutch. I also found myself stalling it more in the beginning... when it starts to lug you push down on the accelerator, right? 😉
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
Mini Excavator Ripper Tooth (A66285)
Mini Excavator...
2006 PROCO 130BBL (A65643)
2006 PROCO 130BBL...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
