4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 18,913
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
Nope. Been there done that.Id say your temp gauge is wonky. Shoot the engine with a handheld IR thermometer.
When using the bush hog after about a hour or hour and a half the tractor gets hot.
The radiator is clean and full, air filter is clean what would cause this?
I think the bush hog is to much for it it's a 5 foot bush hog and i am going really slow 2,3 mph it seems to only get hot when i cut the thick heavy tall stuff.
Would being under powered cause it to heat up? I do not go fast so it does not bog down.
When I cut tall grass I have to clean the grill vents every 30 minutes or so. The grill knocks the seed heads off the weeds and grass and fills up the vents. You might also try turning the pto shaft by hand to make sure the bush hog drive train and blades are moving freely. My engine runs really cold, needle never moves off the top of the "C" until the vents are plugged up, then it shoots right up to above the middle of temp range.I think the bush hog is to much for it it's a 5 foot bush hog and i am going really slow 2,3 mph it seems to only get hot when i cut the thick heavy tall stuff.
Grill panels need to be clean. Screens in front of radiator clean. Radiator clean (better to blow it out than flush with water, I think). Fan needs to be intact, and fan belt tight. Those are the basics and sounds like you're already on it.
Hose it from the inside out. Dust ducked in and got trapped from the outside in do you want to push it out.Rinse radiator with a strong stream of water for about 15-20 minutes
Squirt water straight through being careful not to bend fins.
Youll see what looks like chocolate milk coming out
