Kioti RX6620 check engine light on
/ Kioti RX6620 check engine light on #1
Sean2202
CT
Kubota L305DT
Greetings,
Check engine light came on today with the Kioti RX6620. Tractor has 140 hrs on it and purchased this past spring. The tractor was running fine then started to spit and sputter and then the light came on. All maintenance has been performed so far according to the dealer handout. Regens have been performed when light comes on. If I disconnect the negative battery terminal the light will go off. If I shut down the tractor and come back 10 mins later the CEL will be off. When the light is off after shutting the tractor down it runs 100% fine for a few minutes. Then it will spit and sputter and the foot throttle or hand throttle does not effect performance when its spitting and sputtering. Then the check engine light will come on and the machine will shut off. After restarting with the CEL on the tractor will only run to 2200 rpm. I tried to do a forced regen when the light was off after I disconnected the negative battery terminal and the regen started, a few minutes later it started spitting and sputtering then the machine went back to idle and the regen stopped. Fuel filter was changed again with no difference. No water in fuel filter. Other diesel equipment is all running fine. No other lights on. Air filter is clean. What could be the cause of this malfunction?
Thanks for any help
Sean
/ Kioti RX6620 check engine light on #2
My first thoughts are that something is indeed wrong with emissions, and your in limp mode right now. First make sure its not a fuel issue, so troubleshoot the fuel system throughly. Once your happy the CEL is not fuel related, move on to emissions.
Continue trying for a manual regen, and also check your engine codes for possible cause of CEL. Sadly, Kioti does keep many of the engine codes proprietary, requiring a Kioti dealer and his laptop to sort out what exactly is going on. Sometimes its just a faulty emissions pressure sensor causing the CEL and limp mode.
If you get a engine code reading, post it here and some forum members can provide more information.
Update: i read your original post again, and sounds like your confident its not a fuel issue.
/ Kioti RX6620 check engine light on #3
"Tractor has 140 hrs on it and purchased this past spring."
Isn't it still under warranty? How far is the dealer? If not too far they may send someone over with a scan tool to see what is bugging out.
Otherwise you may have to haul it over to them. Perfect case for the recent "Right to Repair" thread on this forum.
/ Kioti RX6620 check engine light on #4
Give it a few more attempts at regen, and keep the rpm's as high as possible to encourage a regen. Even if its not successful, you now have another item checked and to communicate back to the dealer.
/ Kioti RX6620 check engine light on #5
I’m wondering if you’ve contacted your dealer with the same info? It Would be interesting to hear what they might suggest. Even though you probably have warranty contacting your dealer should have been your first priority. The last thing you want to do is follow someone’s misguided suggestion and create a bigger issue. All the Best and Keep us posted, Dutchy
Thanks for the replies. Yes we have been in contact with the dealer back and forth before posting here and so far they have been good. They are about 1 hour away. Yes it is under warranty. Hopefully they can come down with a scan tool / laptop, otherwise there is a huge sticker on it that states, "trucking for warranty or service work not covered under warranty."
The dealer first stated that its fuel related, water in fuel. Fuel filter was changed. I used water detecting paste and no water in tank. Also cut open old fuel filter and checked for water, none found and no water light on. All other diesel machines in fleet run fine.
Today I figured what the hell change the oil and filter, Oil had 84 hours since last change. Started up, ran fine, forced regen again. About 10 mins in running at 2600 rpm tractor started to spit and sputter, CEL came on then RPM dropped and tractor shut off.
Tried an automotive OBD tester, tester said it could not connect.
After telling the dealer that I don't believe water is an issue, they said it could also be crank sensor related. Not going to fiddle with that. They need to scan it at this point.
I did read another thread on here that someone had trouble with injector dumping too much fuel in and clogging DPF on this tractor at around the same hours.
One other thing to note is that to me it seems to regen a lot. I have limited experience with tier 4 engines and how much they are supposed to regen. I posted about it on here in another thread. Possibly related?
/ Kioti RX6620 check engine light on #7
There should be a warning light for water in fuel. My DK4510 has one:
Yes my dash has a warning lamp for water in fuel. My dash looks different than above. No warning light for water in fuel was ever on or any other lights on during this process except the CEL. No water found in fuel filter or tank with water detecting paste.
/ Kioti RX6620 check engine light on #9
Worse, since Kioti is a small player in the broad diesel industry, universal diesel code readers do not support Kioti. All to say that anytime the "right to work" legislation comes up, vote, "YES!"
I tend to agree with your assessment: something is lying to the ECU that eventually causes the ECU to trip into limp home mode. While not directly related to Sean2202's problem let me tell you a Kioti limp home mode story: In 2014, when I first got my NX, my tractor went into limp home mode because while the ECU claimed it was regenerating (every 8-12 hours), it never got the engine high enough up to temperature to complete a regeneration cycle. As a result, my new 60hp tractor was absolutely gutless. At the time I was super frustrated, and any negative thing said on these forums was ridiculed or deleted. My fix for the poor running condition, as well as the diesel industry fix (because fleets were experiencing the same problem as the limp home problem was a Tier IV spec problem and not just a Kioti problem) was to install a warmer thermostat that allowed the engine to run at a higher minimal engine temperature, one that was warm enough to
1) Stop the engine from continually running on the warm-up fuel map thereby plugging the DPF at a much faster rate, and
2) Also allowing the engine to be warm enough to fully complete a regeneration cycle so the machine wouldn't eventually get tripped into a limp home condition because the DPF was plugged up.
Here is a video of my frustration with my tractor in 2014 before I puzzled out the problem and installed that warmer thermostat.
Also, I should add that if the thermostat has a spring-loaded bypass, then that too can cause the same problem with excessive warm-up times while in use as the coolant can overcome-that weakening spring-loaded bypass and slip right by the thermostat entirely. The condition will act similar to a T-stat being stuck open.
/ Kioti RX6620 check engine light on #10
What really irks me is that it would not take much to flash error codes on the hour meter.
At a MINIMUM we ought to at least get that!
I was asked by my Kioti dealer what dash I had. Apparently from my understanding of the conversation some have this now?. Mine does not.
/ Kioti RX6620 check engine light on #12
Mine is a 2001 DK4510, as far as I know it does not.
/ Kioti RX6620 check engine light on #13
Interestingly, I picked up a fuel filter from my dealer just before closing time, and mentioned your NX tractor CEL issue and proprietary engine codes. According to him, some larger horsepower Kioti's do flash multiple codes on the dash when CEL lights come on (apparently its dash dependent), and all Kioti tractor models by starting year 2023 will be code flashing. A significant help in diagnostic achievement.
During the past 3-years on this forum, a faulty fuel injector more than once, has been identified as a primary cause of a tractor going into limp mode. The excess fuel is unburned, and clogs the DOC/DPF. Happily, the problem can be immediately identified by the dealers laptop. Resolution is replacement of the faulty injector, and is covered by warranty.
Minnesota Eric, much thanks for that post and summary of your regen experience. I read it twice. It never even occurred to me, that a tractor could show a successful regen happening on the dash, but actually NOT BE DOING a regen due to low exhaust temperature thresholds. It just shows very much the needs to keep those rpm's high during a regen to clear out the DPF..
So just an update here. Speaking with the dealer they said that it could be crank sensor related and to unplug the crank sensor while the CEL light is on to see if the tractor will rev up past the limp mode. This was for a diagnose test only and not to be run without it connected. I did not do this.
This morning I started the tractor. No CEL light (I assume the prior code may be stored in memory.) I warmed up the tractor and then used the hand throttle to basically do a regen without pushing the button. Not sure what else happens in the computer / tractor when the button is pushed? So I ran it for approximately 15 mins at 1500 rpm. Then went to 2200 for probably 5 mins. Then full throttle for probably 30 mins. then ran it at 1600 rpm for again for another couple minutes. Then idled it down for a few minutes. The CEL never came on.
After that I shut it off then started it back up and ran a manual regen. The regen light came on and it started the cycle. I came back a while later with the tractor idling and no CEL light on. Seems to have gone through a cycle on its own. Before it was shutting down with a CEL light.
Told the dealer what I did and am monitoring it. We are going to run it next week and see what happens.
/ Kioti RX6620 check engine light on #15
But of course knowing what you stated "Kioti is a small player in the diesel industry" you purchased one anyway.Will your crying about Kioti products ever cease? :poop: Not kiotis fault you used your tractor like a bull dozer then started tampering with everything under the sun on your tractor then complain they won't warranty it.If you hate your tractor so much SELL IT and quit your Pi$$ing and moaning.
/ Kioti RX6620 check engine light on #16
Sean: Happy you got the manual regen started, and cleaned out the emissions issue. Thanks for the feedback.
So an e mail to the dealer to update them on the issue. On the reply the dealer still states that there was "water in the fuel filter and then it got into the injection system" even after telling them multiple times that there was no trace with water detecting paste. They continued to tell me that the fuel filter needs to be changed and drained according to manual. Which I have done. I have also changed the fuel filter two times in 140 hours. Which I would say is excessive especially at about 100 dollars for a fuel filter. Hopefully if there is or was any impurities in the system they are gone.
I will continue to monitor and will update the thread if anything comes from it.
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
2009 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
2022 ASV RT135 MAX-SERIES SKID STEER (A65056)
2022 ASV RT135...
Front Tank Bracket (A64126)
Front Tank Bracket...
