Add a Step
/ Add a Step #1
bsekf
Gold Member
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
I need to add a step to my tractor. Does anybody make something that might work or do I fabricate one?
/ Add a Step #2
I have seen pieces of old conveyor belt supporting a steel step. The conveyor belt flexes when hits an object vs bends like steel frame would
not sure if someone makes a kit or not.
/ Add a Step #3
For my B3200, Kubota has a after market step. I think I paid $15.00 (astounding, isn't it ?) Younger people than I refer to it as an Old Codger Step (or some other term of derision). I think it's fantastic.
When first purchased, I was worried about stumps, etc. hitting it. Never been a problem.
/ Add a Step #4
I don't make any.
/ Add a Step #5
A step is on my list for the Ford but I'm still working on other parts of it. I'm too old to go chasing a flexible step so I'm making one out of two drop down 2" x 5/8" steel. I'll probably cover the 4" x 3/8" landing with expanded metal. Mine most likely won't contact anything since my drawbar is lower than I'm putting the step. I just need a little boost to get to the floor boards. ;)
Oh, I'm also adding some stainless steel grab handles.
/ Add a Step #9
There are lots of bolt on steps available for 4x4 trucks. There are some that are U-shaped stirrup type that would be perfect for a tractor.
/ Add a Step #10
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2011 Mack GU713 Granite Dump Truck, VIN # 1M2AX07YXBM010053 (A61165)
2011 Mack GU713...
UNUSED WOLVERINE SWDB-11-84W HYD DOZER BLADE (A62131)
UNUSED WOLVERINE...
(2) ROW PLANTER (A62130)
(2) ROW PLANTER...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
