Good morning!!!!
   / Good morning!!!! #139,331
I think this speaks to the vaxxed/non vaxxed question raised
From the article: "The purpose of this study is to identify associations between COVID-19 infections, hospitalizations, and deaths among Medicare fee-for-service (FFS) beneficiaries and the proportion of the population fully vaccinated at the county-level between January and May 2021. We do so by using a combination of person-level Medicare FFS claims and Centers for Disease Control and Prevention (CDC) data on county-level vaccination rates. Based on these results, we then estimated the net reduction in infections, hospitalizations, and deaths among all 62.7 million Medicare beneficiaries associated with the first 5 months of the U.S.’s COVID-19 vaccine roll-out. Our results indicate that COVID-19 vaccinations from January until May 2021 were associated with an estimated reduction of more than 265,000 COVID-19 infections and nearly 39,000 deaths among Medicare beneficiaries.
Is this supposed to be good? 265,000 infections in 5 months in Vaxxed Medicare patients only? And 39,000 deaths? Or that is their guesstimate of the reduction????
Why can't we get simple, clear concise, accurate data for
1) "How many new CV cases during Jan-May 2021?" and after to date?
2) "of those new cases, how many were vaxxed and how many were not?"
3) "How many died from CV that were vaxxed?"
4) "How many died from CV who were not vaxxed?"
   / Good morning!!!! #139,332
This is the MedCram video I pointed out to you earlier this week:
I think it explains fairly well why the information isn't available; it's not being collected.
   / Good morning!!!! #139,333
My sisters county in Ohio near Rich, reports 22 current COVID cases, 3 in icu, one of 3 is vaccinated. They didn’t list how many of the other 19 were vaccinated.
Maryland’s numbers are not too bad, seem to be trending back down. My county only reports total number that had it, not how many are active, and no breakdown of vac vs nonvac. I don’t think they want to reveal the true picture, doesn’t fit their narrative.
My county had 27 new cases reported today, out of 270,000 people.
   / Good morning!!!! #139,335
64F sun cloud mix.
Yep another day of "spinning my wheels in the mud" ;) looks like feet up evening.
Enjoy your evening all.
   / Good morning!!!! #139,336
Sounds great
   / Good morning!!!! #139,337
I just deleted a long reply I typed about the current cases in my circle of friends, co-workers, and acquaintance. It isn’t pretty and likely too controversial. So it is gone…..
The delivery went ok. Made great time getting there, they were just unloading the machine when we arrived. Mostly a boring day doing the PDI. I had to do the MSHA training for the mine personnel for new equipment. Mine manager was even civil. It went to work and was time to head home.
Figured how to bring the bike to life. Already made some changes to the shift linkage but more are needed. My standards for how things should be on a race bike kicked in and work needs to be done. Found out the guy I help is racing the Hooligans support class at Charlotte this weekend.
Everyone stay safe out there
   / Good morning!!!! #139,338
65F and partly cloudy @ 20:45, headed down to 59F overnight.
High hit 78.4F today ... was beautiful outside ... (y)
Used Kubota to juggle the pallets around in the barn and got the Cub out first thing.
Woman came out while I was working on the Kubota and worked on cleaning up garage, She got quite a bit done.
Well into the 2400 hour service at this point:
Engine oil and filter changed.
Hydraulic fluid drained and filters changed. Still have to put the strainer and drain plugs back in and refill with that fine TSC Traveller Premium Hydraulic Fluid. Strainer was pretty clean except for a couple of small pieces of what looked like wire. Don't know ... might have come from a failing hose.
Air cleaner housing removed, cleaned (it had a little something in the bottom of the housing that looked/felt like tar), put back together, and a clean outer element installed. Gasket for the lid appears a little dicey, will call tomorrow and see if they have that in stock. If not may have them order one.
Fan belt tension checked.
Anti-freeze condition checked, said good to -20F. Might go ahead and do a flush and fill and change it out at some point in the coming days.
Used new pin to drive out the one in the loader that wasn't taking grease. Unfortunately the new pin I grabbed was too short for that location, so I cleaned the old one up (it definitely has some wear) and stuck it back in there for the time being. Discovered that the grease fitting was where the problem actually was, removed it and used a pick/probe and some carb cleaner + PB B'laster to dig out the dried up grease then used the grease fitting impact/cleaning tool to clear it out to where the juice was actually flowing through it. Just need to throw some grease on it tomorrow and it should be good to go for the time being.
Still have few more items to do (change gear oil in front axle, grease everything, adjust clutch and brake pedals, etc.) to complete the service.
Also have two hard lines and hose to replace as well on the loader tomorrow. There's also another hose I had made up at NAPA a few years ago that's starting to leak, might run down there have them make up another one ... if they have the better quality hose in stock.
Plants from Amazon due in tomorrow via UPS (two days early)
Hope everyone had a great day ... (y)
   / Good morning!!!! #139,339
I don't know that this necessarily answers all the questions you pose, but perhaps it might provide some insights:
Texas has seen nearly 9,000 COVID-19 deaths since February. All but 43 were unvaccinated people.
It would seem to lend some credence to the point that RNG raised: the reason why some statistical data isn't available is because it isn't being collected.
   / Good morning!!!! #139,340
Good evening all. 54F for the start, mostly clear sky and light breeze. Light wind, partly cloudy sky and high temp was 83F, DP 42F. Bike ride in the morning, waited for some warmup before starting. Wife joined me for shopping in town and lunch. Got back too late for both mowing and nap so got the nap in. Had good size hawk on fence but left when I went for camera :( . Gopher going to work anti gopher activities start tomorrow.
Covid update: Cooke 4035 confirmed cases, 28 active cases, Montague 2503 confirmed cases, 42 active cases, Grayson, 15,687 confirmed cases, 224 active cases. Cooke 15, Montague 27, Grayson 101, new cases. Grayson number still don't add up
Don congrats on 4th finish, thanks for Pfizer booster info
Roy hope you dry out enough
Ron good to hear PT is helping, nice pic
Buppies hope you don't wash down the hill from rain.
Drew sounds like nice rain last night, enjoy your slow day
Bird glad you can take advantage of the dryness
Billy sorry to hear you have so many nails in your yard Good to hear you got a hike with lots to see!
Mike sorry about the finger, hope you get some rain
Pual nice day yesterday, hope trip was safe and uneventful.
Ken hope today is productive for you
PJ sorry about the trolls, glad you are back to QA MGR only.
Lou praying for GD and you :)
Drew thanks for info, I think
Phil nice pic
Drew you are right about what they do and risk for us
RNG nice forecast for camping trip, good to hear speedo checks out.nice sunset
Bill get home and start spending money like you had it :)
David hope you learned from the taxing visit. hope you get to the post office in time
RS hope you get the Kubota service with no surprises.
David thanks for link
Dennis thanks for info
Thomas hope you did not get too muddy from wheels :)
Rich glad the bad boy was civil and you got the people trained and machine is at work
RS nice you got the fitting to take grease and no surprises.
prayer for all, especially Jay/Peg, Kyle's daughter/friend PT from Covid, Bird/aging issues/, Don,whipper/more tests,ring bearer/back broken, Randy/FIL living alone adjustments, PJ/FIL fall and stroke, Dennis /wife wrist surgery and recovery, Roy's wife ankle surgery and recovery, David(moss)/remodel/divorce, Buppies/new cancer on arm, Thomas/gout, Phil/reflux/wife's eyes, Steppenwolfe/son-auto immune disorder, Grev/wife's eye, Ted/knee recovery, Doug and wife/health issues/nerve and pain/ wife's eyes, Ken/aunt fall injuries, David(sadamo)/Sophie's eye surgery/Back issues, RNG/fire season, Chris/neighbor's granddaughter and Covid issues, Scaredy/injuries from fall, Paul/ wife's disc issues, and Country.
stay safe and healthy you all.
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2018 JLG 742 TELESCOPIC FORKLIFT (A60429)
2018 JLG 742...
1998 Mac 39' Frameless Dump Trailer (A59814)
1998 Mac 39'...
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
