Shorten joystick after adding 3rd Function Kit??
/ Shorten joystick after adding 3rd Function Kit?? #21
I’d cut the stick and reweld it shorter if you want it shorter.
/ Shorten joystick after adding 3rd Function Kit?? #22
I have cut down the joystick handle on a few different tractors. ITs easy to do to make the tractor more ergonomic and function for yourself. Nothing is worse than doing loader work all day with controls that put your arm in an uncomfortable position
That’s half the reason I like my mini x so much. The joystick controls beside you and sitting beside the boom so it doesn’t obstruct your view is 100x better than sitting straight behind the boom with your arms stuck in front of you all day.
Right! In hindsight, it's obvious. I just didn't give it any thought until after I installed the kit and was surprised that EA and others don't mention or suggest that you'll need to make the adjustment. It would have been very uncomfortable to try to use it way up at shoulder height.
Thanks.
/ Shorten joystick after adding 3rd Function Kit?? #24
On the bright side, whenever I'm doing loader work most everybody waves back.
Some even honk! :LOL:
Land honor Mini Skid Steer (A60352)
Land honor Mini...
2021 Hamm Compactor HD 70i VV Asphalt Roller (A61166)
2021 Hamm...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61568)
2016 Freightliner...
2012 Ram 1500 Crew Cab Pickup Truck (A61568)
2012 Ram 1500 Crew...
Coyote Renegade Trailer (A63116)
Coyote Renegade...
500 GALLON FUEL TANK (A62131)
500 GALLON FUEL...
