/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,061
Guys, I got one thing I wanna address, see if you guys have anything to say about it. When I have the mmm mower deck up in the locked position, I wish it would stay full up. But it still lowers a little bit when I lower the 3ph for a rear implement. Is there an adjustment I could do on the mower deck linkage so that it doesn't do that?
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,062
Funny, I was just thinking the same thing today and was thinking about looking into it. Would also like to know.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,063
I put my flail up for the winter and backhoe is back on.
BH has been resting for a bit, but need to get some work done,
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,064
on my 2400 with deck height set all the way up I can move 3pt and deck doesn't move.
the 2400 has threaded height adjust, know the 1723/1725 had a 5 or 6 notch setting, can't remember what the 1710 had.
maybe linkage between the height limiter and arms themselves?
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,065
My 2015 1710 has a 5 notch adjustment knob for deck height/holding
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,066
So I looked into this further. Attached is the mower lift linkage diagram from the service manual with additional marks by me. I don't know what these parts are called.
Nob 4 causes a metal "Slide" that I marked as "A" to a position between "B" and "C". This is what causes the mower deck to stop at the set height.
The reason that the knob cannot be turned unless the 3PH is all the way up is because the weight of the deck is on "A".
With the deck all the way up the gap between "B" and "C" is larger than thickness of "A", if it was not it could not be moved into position. The difference between the gap and the thickness of "A" determines how far the deck will lower when the knob is in the locked position. I can only guess as to why some see a drop and others don't is that this gap can be different due to manufacturing variances.
There is nothing that can be adjusted to reduce the gap on your particular machine. I did find a video where the person modified "A" to be thicker and thus reduce the drop. In the same video if you watch you will see that a gap of just 1/8 of an inch translated into over an inch of drop in the mower deck.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,068
Only place I have to store it. In this case wheels just keep wood off the ground :cool:
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,069
That's some good homework there, Hube, thx!
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,070
10:45 of that video, exactly what we need, Hube! I'm on it when I'll have the time, yessir!
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
1999 Case IH 4300 Field Cultivator (A59814)
1999 Case IH 4300...
1992 Ford L9000 Cab Chassis with Low Mileage Cummins (A56436)
1992 Ford L9000...
17101 (A55851)
17101 (A55851)
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
