How to repair carpenter bee damage?
   / How to repair carpenter bee damage? #41
As other's mentioned, drill the holes to a known size and plug with wood the same size and some waterproof glue. Cut flush with an oscillating multi-tool.
Have no problem with carpenter bees, but have had serious problems with woodpeckers.
With two hole saws (2-7/8 and 2-3/4) can make the plugs to fit nicely into the holes bored out in the siding. Carpenter adhesive to hold the plugs in has worked well over the last 40 years.
   / How to repair carpenter bee damage? #42
I'm a few days late but thought I'd share. I've found DoMyOwn.com to be very helpful for all of these kinds of solutions. Just type in the name of the offending creature and they will recommend the top professional grade products to get rid of them. I've had luck with Suspend and Bifen IT both for bees. I've also used Taurus SC with good results, mainly because I had it on hand for Carpenter Ants which are worse than Carpenter Bees at my place, and Taurus is great for them. No affiliation with DoMyOwn, just a happy customer. They have good customer service as well. Hope that's helpful.
   / How to repair carpenter bee damage? #43
I don't like bondo brand, but good body filler is likely the cheapest and easiest and most durable option. The quality ones aren't as hard and brittle so you won't run into cracking with the expansion and contraction. They spread and sand better too. And if you buy through a good supplier it's likely cheaper than buying bondo brand at the diy store
   / How to repair carpenter bee damage? #44
What are the general thoughts on this (the following)
We get them little SOB's.... unrelated, I'm debating on replacing the guttering. The fascia behind the guttering seems to be their favorite chomping ground.
(never mind the 9 traps I had that were filled with dozens and dozens and dozens of them)
Anyway, what are the thoughts on replacing the natural wood fascia with one of those composite boards?
For the bees, I'm thinking they're not going to touch/bite it.... but I'm unsure how it would hold up with the gutter attached to it?
Just face your current facial boards by covering with colored steel. They make steel trim for this purpose. Then install the gutters over the steel.
   / How to repair carpenter bee damage? #45
Recently had woodpecker issues too....they were attacking the metal TV antenna tower, metal downspouts on the house, and the metal cladding on my steel barn. They must love the reverb or their brains are getting scrambled.
Lookup Drione dust, it's the best way to treat holes before sealing up, both for adult bees inside and for larva that will grow into a bee
I looked at this and ordered some. Seems better to kill anything inside the holes before filling.
   / How to repair carpenter bee damage? #47
I thought about getting traps for our carpenter bees but it would spoil my wife's fun. She loves to "stalk" them out on our deck and whack them with a badminton racket. She's pretty good at it. She gets 5 or 6 a day during the season.
btw the bees pack a powerful sting
   / How to repair carpenter bee damage? #48
Carpenter bees here do not sting. Never been stung and they don't land on you or try to sting. Been fighting them yearly for a long time. You must be dealing with yellow jackets or something different.
As far as damage . . . I've ripped some 2" x 10" material that they've bored into just to see the damage. It's extensive and they tunnel back horizontally right after making their entry hole into the side or bottom. I think the most economical way to repair the structural damage would be to scab another equal board onto the damaged board and let it overlap far enough back to provide proper support. I've considered doing this with damaged rafter ends that are exposed in the overhang of the barn.
   / How to repair carpenter bee damage? #49
ok possibly so, the sting i got then must have been bumble. was a bad one, but you could be correct, but i won't grab the next one i see @ my place. :) yellow jackets are a whole different beast, been there before running over their subterranean nests while mowing, etc
note from the following link: females do have stingers but are not aggressive. i do remember being stung in the area where they nest on my porch. anyway, to the OP: you have lots of repair opts from this forum, time to get to work, best regards
   / How to repair carpenter bee damage? #50
Not an attack but drumming as a call out to others. They seem to like the resonance of metal. When feeding theiir pecking is not steady or uniform, and they have an uncanny ability to find things below the surface. (larvae, etc) When they're digging at a tree it's a sign of bugs that might should be treated. I see woodpeckers as a warning that a tree may be in danger.
LOT: (1) Craftsman Shop Vac, (1) Dewalt Shop Vac (A59076)
LOT: (1) Craftsman...
LOT: Tap & Die Set, Hole Saw Set, Snap Ring Plier Set (A59076)
LOT: Tap & Die...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
