Is a 60" bush hog ok on a B2650?
/ Is a 60" bush hog ok on a B2650? #1
Rogerss
Kubota
Title says all it's on flat ground but the grass is thick and over the hood of the tractor.
/ Is a 60" bush hog ok on a B2650? #2
It will make it work first pass after that you could take shallower cuts.
I run 5 ft on my tractor with 20 PTO HP and have not stalled it yet. HST is nice since can easily adjust speed
/ Is a 60" bush hog ok on a B2650? #3
If the ground is flat you should have enough power to turn the mower. You may have to proceed slowly the first time or two. On hilly ground I'd worry about the weight of the mower versus the weight of the tractor. If you don't have a front loader you may need some weights on the front.
/ Is a 60" bush hog ok on a B2650? #4
You'll be fine. Remember to have the front of the bush hog lower than the back.
Butting will be eased by raising the deck to max height, and you certainly don't have to engage the whole 60" in cutting. Take 30" swipes, if necessary.
/ Is a 60" bush hog ok on a B2650? #5
Do you have the B2650 now?
Buying a tractor and mower that you know will have to cut only a 30" swathe width does not make sense to me. Maybe ......for one acre, but for more than one acre buy a tractor with at least 33-horsepower.
The 'Bs' are a little tippy. I owned one which I mowed with. There may be surprises lurking within that TALL grass.
BUY ENOUGH TRACTOR!​
No i do not own one now. I seen one for sale is why i asked about it.
I have 17 acres of field to bush hog twice a year to keep it looking nice it's mostly open and 4,5 acres of yard to mow. I inherited the land from my uncle.
I thought a 72" bush hog would be better for the fields and i don't know for the yards. Yes i have two houses now and two yards to mow and pay tax on! yay!
Friends say just buy a tractor and a zero turn. I would like to go all tractor if i could. My uncle used a 46" cub cadet for the yard which i have now and a larger tractor for the fields that was sold to pay off some things.
He also has a long gravel driveway that needs work. In the winter it tends to drift with snow but we don't get that much anymore. The only stuff left is the cub cadet and a rear blade 3pt and a 72" front QA blade so he must of had a kubota QA tractor.
When i was a kid i helped him so i am no stranger to tractors but that was 20 years ago. It used to be a small farm with cows and turkey houses. He was un-able to make a profit all that is gone and in the past.
Forgot to add that i did drive the B2650 and it was fine i liked the seat and arms rest and tilt steering made it easy to get on and off. It was the ROPS one so i am fine with that.
/ Is a 60" bush hog ok on a B2650? #8
/ Is a 60" bush hog ok on a B2650? #9
I have 17 acres of field to bush hog twice a year. It's mostly open. In addition I have 4.5 acres of yard to mow.
I thought a 72" bush hog would be better for the fields but i don't know for the yards.
Here is a mowing calculator:
If your land is fairly flat and fairly smooth you may be able to mow at 5-mph.
A 72" bush hog will mow 3 to 3-1/4 acres per hour @ 5-mph, seven hours to mow 17 acres with a break or two and fueling, cutting full mower width.
Flat ground but the grass is thick and over the hood of the tractor.
(( A 60" light duty bush hog cutting 30" swathe @ 4-mph behind a B2650 cuts one (1) acre per hour. The tractor will be running at full throttle to power the mower. ))
35 horsepower will power a Light Duty 72" Rotary Mower
45 horsepower will power a Heavy Duty 72" Rotary Mower
/ Is a 60" bush hog ok on a B2650? #11
I have been doing as you want to do with my 2015 B2650 which I bought new. I do all of my mowing, rototilling, grading, snow plowing, brush hogging with 60" bush hog brand brush hog, and anything else that needs done with just this tractor. Have 60" mmm and Land Pride 72" rfm for mowing out back. It works very well and happy space wise and maintainence wise with one tractor. I have 1700 hrs on my tractor now, and the only thing I had to replace was hst safety switch. Been a very good tractor.
/ Is a 60" bush hog ok on a B2650? #12
I agree with Rickb that the tractor and 5' mower are a good match.
The real question is whether they are a good match for the property and trying to mow a 17acre field twice a year.
Sounds like the first mow is gonna be really slow going. But once you start maintaining it twice a year you shouldn't be mowing "over-the-hood" stuff anymore.
But a 17 acre field.. if it isn't lawn-like smooth....I think you are gonna find the small size, small tires, and lighter weight of a B to make for a rough ride.
/ Is a 60" bush hog ok on a B2650? #13
It's a weekend project at best with that equipment. Bigger is faster, speed costs money. How fast do you want to go? I agree about the hood-high grass/weeds Timeliness will cure that.
/ Is a 60" bush hog ok on a B2650? #14
For me it would all come down to how smooth it is. Maybe the OP knows, maybe not. But if he ends up with a B and it's as rough as a horse pasture....I don't think you'll ever get over 2-3 mph regardless of how often it's mowed because you won't be able to keep you @$$ in the seat.
If it's yard or hayfield smooth....mowing twice a year....I can see 5mph as tolerable.
That's the difference between getting it mowed in one day... Or two+ days of misery bouncing around on a small machine
If I didn't know the conditions of the 17 acres inherited....I'd probably be inclined (money well spent) to rent a machine for the first mowing. Then you will have a better idea of what size you want
/ Is a 60" bush hog ok on a B2650? #15
Too big for most conditions and nearly all 60" cutters exceed the 500 Lb. maximum recommended weight limitation in the Operator's Manual.
No, I did not say that it could not be done, only that it is too big and too heavy for most conditions.
SDT
/ Is a 60" bush hog ok on a B2650? #16
Agreed.
The short wheelbase and small tires make for a rough ride.
SDT
I am thinking about buying a 72" bush hog and rear finish mower and using the old garden mower to get around the trees and house for the trim work.
I do not know how rough the field is i'm sure it's full of holes lol
/ Is a 60" bush hog ok on a B2650? #18
Well if a bunch of the respondents think a 60" cutter is too big (which I disagree with) I will without any doubt say a buying a 72" cutter to pair with a B2650 is a mistake. But as is usually the case, it's not my cash or my choice.
/ Is a 60" bush hog ok on a B2650? #19
Holes can wreck your day.
The dealer said i can switch them out if i find the B2650 to small would just have to pay the fees for transport $130
He also has a L3901 and a L4701 they where both gear drives. I did not like the seat on them is there a aftermarket seat maker? I think he said the kubota deluxe seat was over a $1000
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
2025 30in. Pallet Forks and Frame Skid Steer Attachment (A61567)
2025 30in. Pallet...
Kubota L2501HST Tractor Package – LA525 Loader, RCR1260 Cutter
Kubota L2501HST...
2014 International DuraStar 4400 Service Truck with Crane, VIN # 3HAMKAAN0EL771639 (A61165)
2014 International...
17109SFL (A61569)
17109SFL (A61569)
