Mt2501fd Wiring diagram
/ Mt2501fd Wiring diagram #1
shawnklock
Mitsubishi mt2501fd
Looking for a wiring diagram for Mitsubishi mt2501fd or similar. Specifically ignition and dash components. I would love to find a repair or service manual but hard to find for grey market tractor.
/ Mt2501fd Wiring diagram #2
It's pretty simple, the most complicated part is the standard ignition pinout for the connector.
What are you trying to identify or do?
Previous owner lost key or broke it off in the ignition, so the ignition switch has been bypassed. It runs the way it is, but I want to replace the ignition switch so that my warning lights, tach, everything on the dash will work. They ran romex from ignition up to the engine, for? Maybe glow plugs? Kind of a mess
/ Mt2501fd Wiring diagram #4
Yup, that's the only thing to have a button for if they couldn't get a diesel ignition switch.
/ Mt2501fd Wiring diagram #5
This would be the wiring. View attachment Scan Sep. 29, 2021.pdf
/ Mt2501fd Wiring diagram #7
Thanks that helps. I’ll order a new ignition switch and tackle that after I’m done splitting this thing and overhauling the clutch
Well if it's only the clutch, that's easy enough.
I had to split in 3 the first time.
/ Mt2501fd Wiring diagram #8
Btw this is likely one of the service manuals you would look for. In addition to the other one or more Mitsubishi ones that match your chassis version.
/ Mt2501fd Wiring diagram #10
My son in law owns a MT2501FD. Where can I find this manual?
Also, can either one of you tell me what type of hydraulic fluid the MT2501FD uses and how much(capacity)?
/ Mt2501fd Wiring diagram #12
I can tell you what type I use, as for capacity it depends on which chassis(es) you have and if you are also doing the front axle.
/ Mt2501fd Wiring diagram #14
Yeah, there are a couple options in the manual. It's more convenient and easier to buy one fluid. Base call is for API GL-3 or better.
The PowerTran is a Agri rated hydraulic fluid. https://phillips66lubricants.com/product/powertrantm-fluid/
PowerTran Fluid also meets API GL-4 performance requirements.
PowerTran Fluid is recommended for use where the equipment manufacturer specifies:
AGCO Power Fluid 821XL, Q-1826, Q-1802 (Type 55 Fluid), Q-1766B
Case IH MS1210, MS1209, MS1207, MS1206
Case New Holland (CNH) MAT3525 (134-D Fluid), MAT3506, MAT3505
Caterpillar TO-2 (obsolete)
Denison Hydraulics HF-0, HF-1, HF-2
Ford ESN-M2C134-D, ESN-M2C86-C, ESN-M2C86-B, ESN-M2C41-B
Ford-New Holland FNHA-2-C-201.00
John Deere JDM J20C, J20D (“Low Viscosity” grade), J14C (Type 303 Fluid)
Kubota UDT Fluid
Landini Tractor II Hydraulic Fluid
Massey Ferguson CMS M1145/M1143, M1141, M1135, M1129A
Sundstrand Hydrostatic Transmission Fluid
Vickers (Eaton) M-2950-S, I-286-S
Volvo VME WB 101 (VCE 1273.03)
ZF TE-ML 03E, 05F, 17E, 21F
/ Mt2501fd Wiring diagram #15
Kubota UDT Fluid
View attachment 716767View attachment 716769
Well, their callout for the Jone Deere J14C as Type 303 is totally wrong. J14C came out some 30+ years later vs. 303. Type 303 is banned in over 26 states. Nobody uses 'whale oil' (type 303) oils anymore.
/ Mt2501fd Wiring diagram #16
"PowerTran Fluid is recommended for use where the equipment manufacturer specifies:"
It's just a suitable replacement list by each manufacturer that is shown, not that each of those in the list are the same thing. None of the items listed are the same thing, if they were they would have the same specification name.
It is not even the full list, just the most commonly recognized ones.
Edit:
At some point John Deere may have had a bulletin that specified J14C as the replacement for Type 303 when it was removed from the market. Is my only get why they have the brackets.
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2) 30'  42" High Pipe Racks (A62679)
2) 30' 42" High...
New/Unused Landhonor Mini Rock Grapple (A65583)
New/Unused...
2022 John Deere 5055E (A60462)
2022 John Deere...
2020 23 Ft. Godfrey Marine Hurricane Boat with 26ft T/A Boat Trailer . (A61574)
2020 23 Ft...
ATS Mini Excavator (A66285)
ATS Mini Excavator...
