X330R deck belt
/ X330R deck belt #1
BiXLL
Just lost my deck belt today. In looking it up, I need part M155096. OEM replacement belt is $98.00! Are these belts better then other "compatible belts? Would you go OEM, or is there another quality belt I can get for a more reasonable price?
/ X330R deck belt #2
JD is infamous for 'special' parts dimensions. Their belts and pulleys for example often use non standard dimensions and angles. Motivation is to drive you to their branded products telling you that others are not compatible and won't work, at least not as well.
Now, with that out of the way, I use compatible belts with no issue on my X300 deck. Go for the general width and length with the knowledge that it won't be exact and may not set properly into the pulleys and sheaves. They will usually work just fine.
Look for blue wrapped Kevlar belts if possible. The wrapping helps when belts run against a backside idler pulley/tensioner. I use either Jason or D&D Powerdive.
/ X330R deck belt #3
Get the JD belt.. or let us know how a substitute works for you. Pls let us know how much less cost it will be for the non JD belt.
Believe there is "extra" stuff in the JD belt, but am not willing to try to find out differently.
Learned years ago with my '68 Wheel Horse mower that all belts are not created equal. Kept trying to get a replacement belt to work, when it turned out WH had special belts made for them to their own specs. And the WH belts worked.
/ X330R deck belt #4
I have an X300 and my experience has been poor outcomes with belts other than JD, including so called Kevlar belts. I think it’s true, as mentioned above, that JD tweeks belt and sheave sizes and mounting angels of said sheaves so you will buy their parts.
/ X330R deck belt #5
Get the JD belt..
TBH I've always gone with the specific JD belt for my D110, and I've always got a spare belt on hand 'just in case'.
I got about 7 years out of the original belt. When it finally 'went', I had a spare ready to go as it's a 4 hour round trip to my JD Dealership. The next time I was in the area, I picked up a new spare. With OEM there's no "I hope this fits" worries.
/ X330R deck belt
I decided to go with the JD belts (deck and drive)and ordered a new set of high lift blades. Should be good to go for a while
/ X330R deck belt #8
I'm a retired JD engineer... my name is on a lot of belt drawings. Sorry, but creating 'special', non-standard parts (whatever that is) is not a motivation.... lol.
Deere has very high life goals for it's components... especially belt drives. So first, the drive is modeled on CAD and hand calculations are made to determine what loads/speeds the drive will see. In CAD you can move sheaves around to be certain that the belt clears other components. It's not important at all that any of the components match "standard" components. It IS important to try and use components that 1) are already in the Deere system (with a proven track record), 2) already stocked on the assembly line (avoids assembly mistakes), and 3) lowers costs by increasing volumes on existing JD parts.
For belts, I always looked in the system to see if a similar part could be used. Maybe a sheave(s) could be shifted to get an existing JD belt to work. Great! If not, you are working with an application engineer (from the belt supplier) that will review the design and make exactly what you need for that application: belt section, raw edge or wrap, cord construction, length, etc.
Make sense why the belts/sheaves hanging in Tractor Supply are not a consideration?
/ X330R deck belt #9
Your claim that the belts and pulleys are not specific to JD doesn't pass the smell test.
From reading you post, I see that you did not necessarily design any pulleys or belts, but just used what has been used in past designs.
And from your own post, you stated, that if you need a new length belt, you ask the belt mfg to make a belt that fits the existing pulleys. I don't see anything in your post that denies that the JD makes a uses pulleys and belts that are not common in the industry.
/ X330R deck belt #10
No. Not at all. What it does say is that JD wants customers to buy JD parts and ONLY JD parts. This gets into the while 'right to repair' issue. I'm not intersted in feeding JD's coffers. I'm interested in getting the best value for my money. I'll buy generic parts.
/ X330R deck belt #11
Wow... you two need to chill.
I am just giving you the background into tractor design and production because you clearly have no clue. There is no 'motivation' to use only 'special' parts. JD is no different than Ford, GM, or Toro in this regard.
In my 30 years at JD, I only had to design a few special sheaves (to drive brand new mower decks to the proper tip speed comes to mind). JD has many hundreds sheaves/idlers in their system ranging from 2" to 20" dia. Every sheave I found was the typical 38 deg 'standard' angle. The belts in the system were HA, HB, HC, etc with the typical 40 deg 'standard' angle. Like any OEM, you cannot spend $60M+ to design, build, and test a tractor program only to find out that the 'standard' belt you purchased from "Tractor World" has changed materials without your knowledge. To maintain design integrity, you work with handpicked suppliers and own the tooling for each part... this is no different than any other OEM.
As you have pointed out, you have successfully strung generic belts around your JD drive and it worked great... sounds 'standard' to me. Quit bitching.
/ X330R deck belt #12
Oooh good! I finally have that engineer's name to curse... Kidding really. Deere decks generally make sense from an application and repair stand point. I could name a couple that I didn't care for. But then I remember MTD... Best to you. As I've said before, you must have had an interesting career. You ever want to start a thread on deck design, I'm in!
/ X330R deck belt #13
Do I sense mower deck frustration??? Ha! Thanks for the post! You have no idea... I've been close to leaving this site multiple times but your post reminds me that there are people here that understand the equipment they talk about.
Yes, Deere hasn't had the greatest reputation in decks... they know it too. I think it's because they are a tractor company first. Years back though, they hired away Simplicity's (best in class) top engineer and put him in charge of mowers. Great move because decks are really hard to design and super frustrating. Your post eludes to this as an owner. I had two stints as a 'deck head' over the years. Some of it was even good times! ;<) The OP writes about a belt for his X330R... I was plucked out of the deck group in '06 to be put solely in charge of that tractor! Back in the deck group, however, that mower left its engineer so mentally broken that he left Horicon vowing never to return!
Decks are a black art. We always tried to apply the latest engineering technology to improve the process: build expensive prototypes, ship them to wherever good grass is, test, test, test, and then repeat. I talked my boss (the Simplicity guy) into working with a top university who was having success modeling helicopter rotors for the government. We met and I sent him all of our models for a mower we knew a lot about (how it cut, strengths, weaknesses, etc). 3 months later we reconnected with the chairman of the department. He said "we analyze rotor blades for the government and have much success... your product is essentially THREE sets of rotor blades, covered with a shroud, AND you introduce mass! (grass)... Impossible!!!" We tried some of the suggestions he offered with terrible results. Sooooo, back to 'black art' method.
A thread on deck design? I jumped into a thread once talking about cut quality... killed the conversation faster than corn through a goose.
I thought "Wow, don't go there again!" Anyway, thanks again for the post!
/ X330R deck belt #14
Interesting story. We got glimpses of some of this being a Toro dealer. IE when there Recycler deck technology came out they would show us water tank tests and other illustrations of how the kickers and accelerators supposedly managed the grass. As a dealer, that was good info for both the sales side and techs who dealt with quality of cut issues. Still have the QOC manual. Been in the old Gilson plant and Tomah factory. Still remember a couple of demo days on new products. One where they had to bring snow in to demo the new CCR technology. Toro seemed to listen to dealer input when designing the XI series. Deere do much the same? Wisconsin was prime territory for the OPE industry. And geese... So no, you shouldn't go anywhere. You're a good ally to have on the forum.
/ X330R deck belt #15
I was unhappy when Deere changed the 54" deck design from the "old" 54" to the newer 54C decks (early 2000 years). Came with my new JD X485. Couldn't mow worth 2cents compared to the older decks. My fix was to remove the 54C deck and store it on the shelf and just use the X485 for an extra lawn tractor.
Bought a JD 425 with 54" deck and put the MC519 cart on it for dedicated lawn cleanup, and a JD 455 with 54" deck for regular lawn mowing. Happy camper now.
Invited to a meeting with Horicon engineers through a dealer invitation and discussed the blowout problem with the 54C decks and the "fix" was to add a piece under the deck. Did very little and grass and leaves blew out ahead of the deck rather than the chute. On the 519 cart with the power flow, hardly could tell where the pass was through the leaves on the lawn. Left about 15%, compared to the old setup that close to zero left.
I chalked it up to Deere wanting a more robust look to the mower decks as they were thicker in depth compared to the older decks. I do know there are pressures to change up from old designs.
/ X330R deck belt #16
So are you saying that you are the only engineer who ever had to use the corporate parts ?
Give the rest of us a break and trust me, I have a clue.
So now you are putting to rest the false claims that JD used special angles on their sheaves and belts, and that any "of the shelf" belt will work with the sheave from JD.
A lot of people will be glad to hear that.
With this part of your post, I certainly do agree. Parts vendors have to be certified and verified on a regular bases.
Richard
/ X330R deck belt #17
I would like to comment and add my 2 cents and a rubber nickel.
Ten years later I have had no explanation for why JD eliminated the
single stage snow thrower from its inventory.
In reference I purchased an LA115 with a 44 inch mower deck and the
44 inch snow blower in good faith-bad purchase and even worse dealer.
I purchased from a nearby dealer ate belts and chutes every year and the
special V belts and chute cost me an average of $350.00+ every year.
Added to the fact that I spent 4 hours replacing the drive and driven belts
every year rather than have the dealer do it as they were 40 miles away.
Neither attachment would work with a non JD V belt; in reference I tried to
use Gates A116 V belts as a replacement and the snow blower worked for a
few minutes and then tore the V belt up.
It is bad enough the Dealer sent the snow blower to me without all the parts
installed. I received a JD service bulletin from a friend at another JD dealership
from whom I bought the new E100 from last year stating that a large number of
JD snow blowers were shipped short of parts.
I was advised not to buy a new snow blower for the E100 as the quality of
workmanship for the 44 inch snow blower attachment did not change.
It would be so simple to use a single stage on these machines even with the
vertical crank engines by modifying the belt drive under the tractor with V pulleys,
snubber pulleys and a right angle 1 to 1 bevel gearbox to drive the cross shaft for
the snow blower rotor.
To purchase a single stage tractor and mower now would require investing in a
grasshopper mower which was much more in expense than I could manage.
If I could have purchased a series 1 JD sub compact and a rear mount 2 stage
snow blower I would have but it was not possible.
The 44 inch snow blower is going to the scrap yard on Monday as no one wants it even for
a project snow blower to mount an engine on it and mount it on the rear of the
tractor frame.
12ft T/A Flatbed Utility Trailer (A64553)
12ft T/A Flatbed...
10in. Auger Bit (A65640)
10in. Auger Bit...
2005 International 5900i T/A Gardner Denver Kill Truck (A64194)
2005 International...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
20ft Bi-Parting Gates (A65583)
20ft Bi-Parting...
2015 International DuraStar 4300 Elgin Broom Bear Street Sweeper Truck (A64556)
2015 International...
