dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,594
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
David, You are really going to have to look a lot more closely at nailers for drywall, and plan ahead a bit more to save you extra work later. Your latest video is a good example. In the screen shot below I marked a red box where you are going to have to add a 2x nailer so the drywall on the main wall isn't flapping in the breeze. Just above your level, to your right, in the pic.
It is going to be very hard to nail that in place given the 2x4 you put in there being barely overlapping the main wall stud. As other have mentioned, plumbing walls should typically be 2x6 to make your life easier, but that is water under the bridge. Remember that for your next house
When planning ahead here, it could have been easier to put the nailer in first and then rip the 2x4 down to butt against the nailer, or you could have used a 2x6 stud there in which case the nailer would have enough wood to nail into more easily. Alternately you could just fir out the rest of the wall to the same depth and essentially turn it into a 2x6 wall and then have one flat wall to deal with, and avoid the tiny inside corner. That may or may not cause other problems, but you should be able to figure it out from looking at it.
Given the stage you are at in the build, you need to start looking ahead and planning for nailers all over the place. Around here, the drywall guys won't add them. "that is the framers job" so they will just skip it until the framer fixes it (you, in this case). Sure an occasional mistake happens, but you really want to make sure they have sturdy supports on all corners to attach the drywall to.
The order of the work really makes a difference. Some things are very hard to come back and put in once you have gone ahead and done something else, but others are no big deal. It really sucks when you find you need a nailer somewhere but there is a wire or PEX tube in the way. Things like that cause a lot of extra rework and time, but it is inevitable that you will have an oopsie here and there. Your goal is to minimize those so you only do the work once.
Keep on plugging away!
