Crazy idea?
/ Crazy idea? #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
When the weather gets rainy here in the PNW I will stop tractoring for a while and get the power steering installed on my YM2310. I would really like to use a power steering pump but space is so tight that I may not be able to.
However, there is room for a power steering pump, if small enough, directly above the stock alternator. My crazy plan is to remove the alternator and look at its construction, to see how the rotating part is supported by the bearing(s). If I deem the support adequate, or if I can add another bearing if need be, then I want to put the rotating part in the lathe and remove just enough material such that the O.D. cleans up. Then I will machine a vee belt pulley from aluminum that is a .002 to .003 inch press fit for the alternator O.D. that I just machined. Then I can just heat the aluminum pulley up and drop it onto the alternator. So, is this a crazy idea? If not then I need to find a small power steering pump.
I'm thinking I need to look for a power steering pump from a small import car. A Toyota or a Nissan or similar. Something common. Too bad Yanmar doesn't make small cars. I could go to the closest Pick and Pull auto wrecker yard and just look for a suitably sized pump. I will need to make sure it spins the right direction. That means I need to see which direction my 2310 spins.
Thanks,
Eric
/ Crazy idea? #2
Please post a photo of your alternator and indicate where you want the new pulley. I would be surprised if Yanmar makes their own alternators. Does yours have a manufacturer's label?
Do you have a single belt drive alternator? You can probably find a double pulley and run a small pump off that.
Bruce
/ Crazy idea? #4
I have no idea what you are talking about doing after reading it 3 times.
I think what he is describing is turning down the OD of the alternator (because it spins with the pulley) to true it up and then mounting another pulley on the body of the alternator to drive a power steering pump. If so, I think that would put too much load on the belt driving the alternator (and subsequently the hydraulic pump). I think you would have a hard time keeping that belt from slipping.
I think an easier method might be to just couple the pump to the crank pulley with something like this
/ Crazy idea? #5
Building hydraulic pressure doesn't get you power steering,how will you propoartion and transfer it to front wheels?
/ Crazy idea? #6
Building hydraulic pressure doesn't get you power steering, how will you propoartion and transfer it to front wheels?
Pump with hose connections to a hydraulic cylinder. Much like cars of the late 70s up to the 90s. Lots of YT vids out there on doing this with tractors that never had PS to begin with.
/ Crazy idea? #7
A lot of power steering motors today are electric. Maybe easier to fit.
/ Crazy idea? #8
Yeah. - - Probably adding a pulley to the alternator to drive the add on P/S pump. Lot of power going on the fanbelt.
/ Crazy idea? #9
Hydraulic ram assist. I still have high boys.
/ Crazy idea?
You have it correct, what I am considering. I first looked at coming directly off of the crank but there is no room. I even thought about having the pump below the engine but there is no room there either. The space is taken up with what looks like the front end mounting structure. Regarding the belt slipping think it will not be a problem. I think the biggest problem will the bearing in the alternator, whether it is stout enough to take the load and if not is there anything I can do within season to fix the situation. I have a full machine shop at my disposal so the lathe work should be fairly easy to do.
Eric
/ Crazy idea?
Bruce
OK, here are a couple pictures. There is not enough room between the end of the alternator and the fan to add another pulley. The alternator cannot be moved back because it will hit the oil filter. But there is room directly above and to the left for the right size power steering pump. The yellow X is where I would machine the alternator.
/ Crazy idea?
I think you would be money ahead by doing something like this guy did on his ym2000.
I don't see how I would be money ahead if I did what that you tuber did. His setup doesn't use a power steering pump. if I break spindles on my 2310 then maybe no will look into welding on Deere spindles.
/ Crazy idea?
To further illustrate how I think a power steering pump could work I am posting a couple more pictures. The pump I'm using in the pictures is for a Toyota but I don't know which Toyota or the direction the pump spins so I don't know if I could even use this particular pump. But the pictures show how the pump would fit in the space available.
Eric
/ Crazy idea? #15
Is there enough room for the large pulley you will need for the pump?
/ Crazy idea?
It looks like I can get away with a 6 inch pulley around the alternator and 5 or 6 inch on the power steering pump. I may need to make a pulley for the pump depending on the pump I would end up using. That's no problem, I have made plenty of pulleys. I don't know how fast a power steering pump needs to turn. I would like the power steering to work at idle, just like a car. That may mean a smaller pulley on the pump. Now that I'm considering a crazy idea I'm really getting warmed up again to the idea of keeping the power steering hydraulics separate from the tractor hydraulics.
Eric
/ Crazy idea? #17
Eric
Is it possible to mount above the water pump? a nice thick 1/4 steel bracket off of the Toyota. ;)
/ Crazy idea? #18
Most car pumps Iv seen spin at about crank speed. Your drive pulley on the alternator is spinning almost 2x crank speed. May be ok to run the pump at 2x but ? necessary. Its just more power stepping up through that small pulley alternator drive. If you could find a short multigroove/serpentine belt for the secondary it might reduce the pulley groove depth overhead enough to ease making prudent speed choices. - - More efficient too.
/ Crazy idea?
It would be higher than the water pump but will not fit directly above it. I really need to go to the Pick and Pull auto dismantlers and look at power steering pumps. It would be really nice if I can find a pump that has its own reservoir and fits in the space available. I would rather avoid a separate reservoir, especially since the one from the donor car may not fit where I can put one. Still, I can easily weld one up. I have the material, equipment, and skill needed to do the job.
/ Crazy idea?
Upon closer inspection I see what you are talking about. There is a passage, basically, below the radiator and then on through what looks like a big cast weight which sits under the battery. The shaft from the end of the crankshaft would need to extend right through to the front of the tractor and the pump would then need to hang out in front of the tractor. I could use a shorter drive if there was room to hang the pump below the tractor but there isn't. If the battery wasn't where it is the pump could go there. But it is and the battery can't be relocated.
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
2018 Chevrolet Cruze Passenger Car, VIN # 1G1BC5SM5J7145503 (A61165)
2018 Chevrolet...
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
2013 MACK GU713 CAB AND CHASSIS (A60736)
2013 MACK GU713...
