Loading issues on Dump Trailer
/ Loading issues on Dump Trailer #1
s219
Super Member
Virginia USA
Kubota L3200, Deere X380, Kubota RTV-X
I got a 6x12 10K dump trailer earlier this year. Due to tow limits of my 1/2-ton truck, I never purchase more than 3 tons of material. When loaded properly, the trailer tows great. But I'd say 80% of the time, the local yards load me with a forward bias, creating too much tongue weight. I picked up three loads today and they were all forward biased, some worse than others.
I installed a W.D.H. to help in these situations, and it does what it is supposed to but won't cure poor loading or too much tongue weight. While pulling onto the scale for my first load this morning, I carefully noted the measurements as each axle went onto the scale, before and after being loaded. While eating lunch I did some math. The trailer has only 300# tongue weight when empty, which matches what I measured with a bathroom scale a couple months ago. When loaded too far forward, tongue weight was 1140#, more than my truck is meant to handle and visually way too much even with a W.D.H. If loaded evenly, it should have been in the 700-800# range.
I'm trying to decide how to deal with this. At this point, my only solution is to carefully raise the trailer bed to shift some of the material rearward, but that is a pain to do and needs careful judgement (not all loads slide the same). I am wondering if I should fab up some sort of sealed chamber at the front of the trailer bed to block off volume so that material cannot physically occupy the front couple feet of the bed (it would have to be angled to force material to flow to the rear). Somehow I need to prevent operators from loading with a forward bias and the only solution I can think of is to eliminate that volume. Any other ideas?
/ Loading issues on Dump Trailer #2
If your material can shift by tilting the front I would say it could also shift when being hauled. I would say cut out some weight and maybe make two trips.
Forgot to add photo, this was one of the loads from today:
/ Loading issues on Dump Trailer #4
Dang. Best bet for a 10k 6x12 dump is definitely to just pull it with a 2500/3500 pickup. But! You got what you got.
cant just tell the loader operators, every single time, to “load it centered on the trailer axles”? Dont be shy, get out of your truck and point your arms if you have to. But, Definitely a lot of room for heavy tongue weight with your axle placement. You could build a 45° Plywood ramp at the front 2 or 3 feet, to show the loader guys.
/ Loading issues on Dump Trailer #5
I borrow my neighbors 10k 6x10 dump
Trailer a lot. Imagine the same trailer but 2 less feet in front of the axles. Better weight distribution and essentially hauls the same load (3 yards or 3.5 tons).
/ Loading issues on Dump Trailer #6
I always get out and physically show the loader where I want them to put the material. Have only had a issue a few times. Since it is a safety and legal issue if its loaded wrong I got in the truck, backed up to their pile and dumped it. Got some nasty looks a couple of times but its better than moving it by hand or having a wreck.
As far as actual idea to prevent loading to the front thats a tough one. Something sturdy is going to reduce your load capacity. What about a few large cardboard boxes with a bit of weight in them placed at the front of the trailor to help reduce the loading issue. No great loss if they get messed up. Couple half’s of a barrel turned over bottom side up?
/ Loading issues on Dump Trailer #7
I have a 8x14 14k that I pull with a f150. I've only once had to much tail weight. But it was a goofy load of wet dirt. It's really hard to load it with to much tail weight. However your wd hitch isn't tight enough if it can't LEVEL out your truck with 1400 lbs. I've had over 20k in my trailer by complete accident and the wd did its job leveling my truck. I'm pretty sure my bars are only 1k or 1200lb also.
When I used my dad's 6x10 suretrac you wouldn't be able to lift the bed long before you truly overloaded your truck
/ Loading issues on Dump Trailer #8
Your local yards have hack loader operators who Don't Care. You buy the product and you tell
them how it should be loaded. And, you are pushing your luck with a half ton with that kind of weight. Trailer weight and product are over you recommended payload.
/ Loading issues on Dump Trailer #9
Weight ratings aside...
Maybe some different colored conspicuity or marker tape on the upper side panel edges.
Apply some wide Yellow Caution tape along the most forward rib section...
Leave the center section as is, else Green tape or something similar over the axles to make it obvious for the loader where to center the load.
A couple of heavy plastic 55 gallon barrels strapped into the front section would displace a fair part of the space at the front, plus visually encourage the loader to center over the axles.
You might even find black ones to match the trailer to keep the neighbors from talking bad about you!
/ Loading issues on Dump Trailer #10
Depending on how much/many loads like that you haul, I’d consider a heavier sprung/axle truck. Can you trade in your truck and come out ok financially?
If it’s just an occasional thing, bring a shovel and be prepared to do some “load rearranging“ after they load your trailer. :)
IMO, 1/2 tons are underrated for a dump trailer that size.
Looks like you have a nice contracting gig going…..maybe time to “upgrade” to something bigger.
/ Loading issues on Dump Trailer #11
A sheet of 3/4" plywood and some 2x4's should block that front area off. Make a shelf and put the rest of the sheet at an angle so the material has no where to go but back.
/ Loading issues on Dump Trailer #12
^ what tin hack said. One sheet of ply and a few studs, one hour of work and you're set.
Actually I do like BackRoads suggestions, too. A few rows of caution tape across the front portion would be a good visual indicator to the loader guys (but maybe not hold up at roadway speed) ?
/ Loading issues on Dump Trailer #13
Okay, you are making me appreciate my loader operator, we communicate on a CB radio and he tries to load my dump trailer evenly and he will even take his bucket and knock the top down where it does not show above the trailer sides.
/ Loading issues on Dump Trailer #14
I cringe so hard every time a loader operator does this to my neighbors dump trailer. Sometimes its nice and smooth, but they occasionally slam down an extra couple thousand pounds of force, when we're already loaded at max tongue weight, max GVWR and max GCVWR.
/ Loading issues on Dump Trailer #15
1100 lbs is not too much hitch weight for that trailer. Set your WD hitch better. You need that much, if you are 10k trailer gross. Not enough weight, will surely give you control issues.
/ Loading issues on Dump Trailer #16
How many times has something broke?
Are your springs broken or bent?
Did he damage the sides?
What is it that makes you "cringe"?
/ Loading issues on Dump Trailer #17
If it’s 1100 lbs when it should be 800 lbs, does that mean you’d (ideally) have to rake about 150lbs from the front to the back?
Well, maybe more or less depending on tongue length and box placement above axles, etc.. but probably not as much as you think. I have a gravity dump trailer for hauling fire wood. There are times when tongue weight is so heavy I can’t even begin to lift up the front to dump it. It surprises me how after only moving a couple dozen pieces of firewood from front to back it will usually dump by itself.
/ Loading issues on Dump Trailer #18
What makes me cringe is that a good loader operator can gently flatten the dirt/stone out in the dump bed. But a bad one applies tons of additional down pressure from a 20k lb machine when I am already loaded at full capacity, and you never know which operator you're gonna get. 10k lbs in the dump bed is a heavy enough load - watching the trailer compress another 6" from a pointless loader drop is not fun. Nothing has broken yet - it's my generous neighbors, not mine. Should I just enjoy watching this happen, until something does break?
You must drive a loader in the yard, eh? lol.
/ Loading issues on Dump Trailer #19
Most weight limits on trucks & trailers is performance related, NOT structural.
Based on stopping distances & how fast you can climb a hill.
You are no where near breaking anything.
/ Loading issues on Dump Trailer #20
It would have to be a pretty small loader to be 20k. And they’re used to loading dump trucks all day. They’re much more durable.
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63688)
2019 Cadillac...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
John Deere X500 Riding Lawn Mower (A66285)
John Deere X500...
2013 JOHN DEERE S550 GRAIN COMBINE (A64277)
2013 JOHN DEERE...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
