Lets test some grease!
   / Lets test some grease! #1
k0ua
Epic Contributor
Branson, Mo.
Kioti DK35se Hydrostat
Lets see how a low end grease compares to Lucas Red and Tacky
   / Lets test some grease! #2
I’m actually surprised how much difference there was.
   / Lets test some grease! #3
supertech sells a red grease, not sure why it wasn't the comparison as its literally a dollar more, which i have used for years on everything including trailer bearings. 0 issues for me
supertech red
   / Lets test some grease! #4
supertech sells a red grease, not sure why it wasn't the comparison, which i have used for years on everything including trailer bearings. 0 issues for me
supertech red
You could spend a year testing grease and not test them all. Testing a grease that cost half as much vs grease that’s nearly the same price is a better test IMO.
   / Lets test some grease! #5
I have never seen a grease related failure.
What does a grease failure look like, other than the obvious of having no grease. I mean, if there is grease in the joint or bearing, and it fails because of the grease, how can a person tell?
   / Lets test some grease! #6
Most of the time a joint that was actually well greased never fails at least on residential equipment.
   / Lets test some grease! #8
For this board, where most of us use our tractors less than 200 hours/year it's probably more important to make sure it's all greased than worry about the specific brand of grease.
   / Lets test some grease! #9
Generally a grease related failure is from incompatible types of grease. Many people flock to polyurea because it synthetic but if you look at a grease compatibility chart it reacts bad with just about everything. We see this at work all the time when mixed with lithium it turns to a rock as a prime example
   / Lets test some grease! #10
I've seen grease failures two times forsure...
The grease failed to stay in a properly greased bearing, so the bearing failed...
That's a grease related failure.
SR
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A50860)
2025 K0311 UNUSED...
2 Vintage Metal Signs (A48082)
2 Vintage Metal...
1997 John Deere 8100 MFWD Tractor (A51039)
1997 John Deere...
Kubota ZD331 Diesel Zero Turn Mower (A50860)
Kubota ZD331...
LOT LOCATIONS (A51219)
2014 Ford F550 Crane Truck (A50323)
2014 Ford F550...
