m9540 Kubota
/ m9540 Kubota #1
Longr
2011 m9540 kubota
Need to flush cooling system on my m9540. Want to flush block and radiator. Am not sure where to drain the block. Both radiator hoses attach to the block too high to assist in draining the block. Appreciate any assistance.
/ m9540 Kubota #2
Can you drain it out of the lower hose? If you have a cab is the heater return hose low enough? What does your WSM say?
/ m9540 Kubota #3
Do you have the operator's manual? My Kubota manual shows how to drain coolant from the rad and block. On the M7040SU there is a bolt near the oil fill plug that you unscrew and the coolant drains out.
Leeboy 8530 Paver (A61166)
Leeboy 8530 Paver...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
2014 Infiniti QX60 SUV (A61569)
2014 Infiniti QX60...
UNUSED KJ 20' BI PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20' BI...
SET OF 26' & 36' GATES (A62131)
SET OF 26' & 36'...
(4) Trail Quest 235/80R/16 Tires and Rims (A64047)
(4) Trail Quest...
