Miller 225g welder replacement engine
/ Miller 225g welder replacement engine #21
I've rebuilt 4-5 of the Onan's on Miller Welders. If yours has an oil filter it is probably an Onan Performer. If no filter it is a CCK.
IIRC the crank can be turned .040 under but I might be thinking about the cyl bore.
You are not going to get a replacement engine cheaper than repairing yours if you are looking at new. And then you will need the engine adapter.
If you look around there are a lot of RV generators from scrapped RV's. I just bought one on craigslist for $160. that has the control PC board missing. These gens run at 1800 RPM so the engines last forever.
The crank is also tapered so a regular engine won't work, it has to be a generator version. The gen has no bearing on the engine end.
Is there anyway to make sure that the Onan RV generator a person potentially buys will have the same shaft as on their Miller bobcat (e.g. by model numbers years serial numbers, etc)?
/ Miller 225g welder replacement engine #22
Do you realize that the last response on this thread was posted nearly THREE years ago?
/ Miller 225g welder replacement engine #23
Just an FYI, even though this is an OLD post - There is a company that specializes in re-powering equipment like welders, mowers, small tractors, etc. Oddly enough they are called Repower Specialists.
They have a lot of info regarding the different shafts on Miller welders & are a go to source for the correct information. Who ever heard of a Honda engine on a Miller Bobcat? Expensive, but very easy to swap out - I did it on an 89 model, it was painless - took about 3 hours.
