Get rid of those bent axles!
   / Get rid of those bent axles! #1
dusty3030
West TN
Kubota MX5400 Cab, Kioti RX7320 PS/ Cab, Kubota M7040 HDC, John Deere 2355, Kubota U35-4, John Deere 317G
   / Get rid of those bent axles! #2
Well no camber is going to be better than that really bent one. But I dont see the person who's overloading a trailer that much even knowing there axle is supposed to be bent..but the other way.
   / Get rid of those bent axles! #3
In his spare time maybe he could straighten some of those semi flatbeds I see going down the road. Honestly, how do they get away with such an obviously unsafe trailer? Empty they have a big upward bow in them. The metal is so fatigued that when loaded, that bend straightens right out. It ain't right I tell you!
   / Get rid of those bent axles! #4
I would think someone with a machine that large and the capabilities to use it would understand how this works.
   / Get rid of those bent axles! #6
Redneck Trailer Supplies builds axles to order and has distribution centers across the US. I've had axles built there for customers a couple times and the process is smooth and efficient.
We used to haul axles made at Dexter Axle in Elkhart, IN to a few Redneck factories. They must have decided to build them themselves.
   / Get rid of those bent axles! #7
   / Get rid of those bent axles! #8
For all I know Redneck farms the builds out to Dexter. That wouldn't be all bad. They are, after all a distribution and retail business, not a manufacturer.
   / Get rid of those bent axles! #9
Perhaps those trailers are purposely designed that way. If the empty trailer always returns to the bowed position the material is not fatigued.
   / Get rid of those bent axles! #10
Long time ago I heard they are designed so when load is maxed out the axles will be straight and even with semi flatbeds the trailers will be flat when loaded down.
2014 FORD F-350 CAB & CHASSIS (A58214)
2014 FORD F-350...
PALLET OF TIRES & ROOF TOP CARRIER (A58374)
PALLET OF TIRES &...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
VINTAGE MERCURY MODEL K OUTBOARD MOTOR (A58374)
VINTAGE MERCURY...
ARTIC AIR SALAD BAR (A58374)
ARTIC AIR SALAD...
HAMM H11 PADFOOT ROLLER (A58216)
HAMM H11 PADFOOT...
